Clutch Levers?????
- Has thanked: 10282 times
- Been thanked: 6894 times
Clutch Levers?????
Why are there so many different ones?
The missus fell off the other day and bust hers. No problem I thought. Will be easy to replace. After a quick search I realise there are dozens of different designs.
It's hardly rocket science. They only need to pull a cable. They don't need a fancy design or add value to a bike.
When a company designs a new bike they seem to ignore all the readily available designs, opting to design a new one.
I know that hydraulic clutches need one to match the MC but not cable ones.
Baffled of Lanzarote
- Has thanked: 261 times
- Been thanked: 1267 times
- Has thanked: 2554 times
- Been thanked: 6262 times
- Has thanked: 2948 times
- Been thanked: 1884 times
Re: Clutch Levers?????
You must work in the MTB industry.....
- Been thanked: 7544 times
If you broke the lever on your Suzuki, I'm sure Suzuki would much rather you buy a new one from them, than the Kawasaki dealership.
Nobody buys OE levers.KungFooBob wrote: ↑Sun Oct 10, 2021 5:49 pm If you broke the lever on your Suzuki, I'm sure Suzuki would much rather you buy a new one from them, than the Kawasaki dealership.
The local shop had one the same style. But had to grind 2mm off each face where it goes into the pivot thingy.
Missus is happy now so she can go out with her little pal on Friday
- Has thanked: 5456 times
- Been thanked: 13103 times
Why not? I'd rather trust my wife's bike with standard equipment that works over something that's ground a few mm off and looks like it mostly fits ok. What if it isn't quite ok and doesn't pull the clutch one time as it's not perfect?Yorick wrote: ↑Sun Oct 10, 2021 7:03 pmNobody buys OE levers.KungFooBob wrote: ↑Sun Oct 10, 2021 5:49 pm If you broke the lever on your Suzuki, I'm sure Suzuki would much rather you buy a new one from them, than the Kawasaki dealership.
This is just a bodge till the right one comes from UK.weeksy wrote: ↑Wed Oct 13, 2021 8:14 pmWhy not? I'd rather trust my wife's bike with standard equipment that works over something that's ground a few mm off and looks like it mostly fits ok. What if it isn't quite ok and doesn't pull the clutch one time as it's not perfect?Yorick wrote: ↑Sun Oct 10, 2021 7:03 pmNobody buys OE levers.KungFooBob wrote: ↑Sun Oct 10, 2021 5:49 pm If you broke the lever on your Suzuki, I'm sure Suzuki would much rather you buy a new one from them, than the Kawasaki dealership.
It's from a YZ250 and it's a good bit of kit.
