Mending cracking headlight cowl?
Asian Boss
Has thanked: 498 times
Been thanked: 650 times
Post by Asian Boss »
The headlight cowl on the old XL is cracking. It was like this when I got it but I think it's getting worse.
I haven't investigated but I suspect there's no spacer or bolt with a shoulder on so that may have caused the problems and is making it worse.
Any advice in terms of mending the plastic? Might going at it cack-handedly with a soldering iron from the inside work? I suspect most glues won't hold. I see there are various kits and products designed to do this sort of thing, has anyone any experience of those?
Has thanked: 5450 times
Been thanked: 13085 times
Re: Mending cracking headlight cowl?
Use an old fairing cast off and basically solder it, that's essentially what plastic welding is
Been thanked: 2616 times
I've probably got a prepatinated bolt and top hat washer if you want them.
Asian Boss
weeksy wrote: Wed Oct 06, 2021 6:49 pm Use an old fairing cast off and basically solder it, that's essentially what plastic welding is
I don't think I have any old pieces of fairing. I should take the cowl off and see if it says what sort of plastic it's made from. Then try and get some, there's probably a pipe or something made from it.
Asian Boss
cheb wrote: Wed Oct 06, 2021 6:54 pm I've probably got a prepatinated bolt and top hat washer if you want them.
Thank you, that could be really useful. Those sort of things can be a nightmare to find.
Has thanked: 6187 times
Been thanked: 5087 times
Never done this sort of repair, but two things I've read are:
- drill a hole at the end of the crack to stop it spreading
- on the inside of the panel, cut the crack to a 'V', then fill/glue into that
Have you looked for youtube videos?
Has thanked: 218 times
Been thanked: 689 times
There is a tool that sets a wire accross the crack and braces the repair. I think screwdriver had one...might be worth asking his opinion any way as he is aces at mending and making....
Has thanked: 6376 times
Been thanked: 4751 times
If you have some Airfix glue, put a blob on the inside, then scratch it off. If you it dissolves a bit of plastic you can use the solvent based adhesive to at least hold it together while you work on it, or even glue a reinforcing piece on the inside. If it doesn't dissolve, glueing can be a problem - a bunch of us tried all sorts on some plastic components for a lighting installation and nothing really worked.
There's also a fine metal you can get, place over the crack and poke in into the plastic with a soldering iron.
Dirt bikes have use different plastic (that's a lot more flexible) to road bikes, I've got a feeling it's very difficult to plastic weld, but I can ask Brian the plastic welder, if you want it done professionally I can put you in touch with him.
If it was mine I'd be looking for a replacement, you can get pattern bodywork for most of the common Honda dirt bikes from yesteryear
Been thanked: 7526 times
It's fucking fucked.
Set it on fire and claim on the insurance.
Asian Boss
I took the cowl off. Top hat spacers present on both sides, original I presume. No sign of identification markings on the plastic so I have a bash at it with an old soldering iron. It seems to have done the trick! Maybe it will break again as soon as I start it up.
derek badger
Has thanked: 769 times
Been thanked: 1135 times
Post by derek badger »
Its an ugly fix, but I've had good success with this method...
Get a 1mm drill bit and stainless steel lock wire. Stitch it up like you would do a wound then cover it in epoxy resin.
Asian Boss
I think it's cracked again.
I need to to look reasonable as it's highly visible.
I might buy some plastic welding rods and have a go with those.
Does anyone know how to tell what sort of plastic it is?
Asian Boss wrote: Mon Oct 18, 2021 3:24 pm I think it's cracked again.
You could try a flame test. It's not exactly definitive but worth a try?
https://www.twi-global.com/technical-kn ... a-plastic
PS The commonest plastic for them is ABS.
It's dirt bike plastic, it won't plastic weld, it shrinks when it melts, just buy another and stop being a tight wadge
Asian Boss
Le_Fromage_Grande wrote: Mon Oct 18, 2021 4:19 pm
If I could find one I would but it's a very rare bike.
Stick a picture of it up showing the whole shroud, it's bound to be the same as another Honda, I might be able to suggest some to try.
Screwdriver
Has thanked: 256 times
Been thanked: 740 times
Post by Screwdriver »
Hot staple is what you need for that. You can also plastic weld polypropylene (if that's what it is) but you'll need a hot air welding gun. Soldering iron is too hot and will burn the plastic (it will also burn ABS).
Plenty of people out there will tell you they can shove a soldering iron into plastic and "look I fixed it". Fact is, they have made a brittle repair which will crack and split as soon as you try and flex it.
Asian Boss
Screwdriver wrote: Tue Oct 19, 2021 1:40 am Hot staple is what you need for that. You can also plastic weld polypropylene (if that's what it is) but you'll need a hot air welding gun. Soldering iron is too hot and will burn the plastic (it will also burn ABS).
That sounds like the repair I did!
I've Googled hot staplers, they sound like they will do the job. :thumbup:
