E10 in an old bike
Asian Boss
Has thanked: 498 times
Been thanked: 650 times
E10 in an old bike
Post by Asian Boss »
I panic-filled the XL with E10 a few days back.
It's a 1984 bike so not compatible. Any idea how quickly I need to get it out before it banjaxes something?
I've been using it to try and run the level down but it uses so little it's never going to work.
Been thanked: 7544 times
Re: E10 in an old bike
It's going to be utterly fucked by now.
I'll give £250 for it, but I'm cutting my own throat.
Or you could put some of this (or similar) in it.
https://www.toolstation.com/b3c-ethanol ... lsrc=aw.ds
Has thanked: 218 times
Been thanked: 689 times
I agree with kfb..but it's only worth £125 including delivery...i will be in on friday.
Has thanked: 9848 times
Been thanked: 10160 times
Never mind that E10 bollox,just gan it up on t' back wheel. :thumbup:
Bigyin
Has thanked: 1413 times
Been thanked: 2680 times
Post by Bigyin »
As i understand it the problem is either continued use of E10 or leaving it to stand with E10 in it which will have an effect on a plastic tank or carb rubbers.
I doubt a single tank will fuck it but 50 quid and i'll take it off your hands to remove the stress and worry for you ;)
Screwdriver
Has thanked: 256 times
Been thanked: 740 times
Post by Screwdriver »
I rather suspect the bigger problem will be chainsaws, strimmers and other petrol driven garden paraphernalia. All plastic tanks, none of the buggers ever want to start anyway after six months tucked away in the shed.
It's a deliberate act of sabotage! </tinfoilhat>
DefTrap
Has thanked: 2267 times
Been thanked: 2193 times
Post by DefTrap »
My chainsaw has had e10 in it for ages. Bikes too.
I tend to think there's a lot of people with shit machinery and terrible maintenance schedules just looking for excuses.
Been thanked: 2623 times
And for all the amount domestic garden machinery uses it's no great expense to use Aspen petrol or petroil.
Asian Boss
Thanks chaps. Maybe I shouldn't papper mesen.
It really uses so little, the level's still up in the filler neck.
I think using E5 super unleaded could also be an answer (to a problem which may not exist...!).
Screwdriver
DefTrap wrote: Wed Sep 29, 2021 8:16 pm My chainsaw has had e10 in it for ages. Bikes too.
Outnumbered by miserable old humourless assholes I'll wager.
Has thanked: 600 times
Been thanked: 2453 times
DefTrap wrote: Wed Sep 29, 2021 8:16 pm terrible maintenance schedules
You mean chucking it in the back of the shed until next year isn't a good thing?
Ah well, it's worked so far for the Hayter so I'll keep the schedule going
wull
Has thanked: 881 times
Been thanked: 1552 times
Post by wull »
Going by the fuel Shenanigans at the moment the £10 fuel is worth around £367 so ignore the offers and double the price
Been thanked: 4125 times
Fuel separation and the following water absorption causes the green slime, the bigger problem is the ethanol damaging rubber parts, some it shrinks, some it grows, some harden, some dissolve, but if you use it regularly so the fuel doesn't sit, it seems to be less of a problem.
My 31 year old FZ750 gets used regularly and doesn't seem to have any problems, my Kawasaki I rarely use and I have loads of carb problems.
Has thanked: 2554 times
Been thanked: 6262 times
You wouldn't believe how many tedious arguments (or maybe you would) there are in OEMs and the like about tiny little details like that. It's the difference between a proper OEM product and something made in your shed.
As for ethanol - the auld Triumph has been upgraded with ethanol resistant seals and floats throughout. We shall see if they actually work! I think it might be a moot point anyway, 'cause the fancy high octane fuel she needs on account of her high compression pistons doens't actually have ethanol in AFAIK.
Tomcat
Has thanked: 65 times
Been thanked: 129 times
Post by Tomcat »
There was a big post on FB from a chemical engineer about E10. Short version, just use it as normal. Fuel injected bikes can use it OK but older ones with carbs might find it rotting seals if used over a long period. Just burn it as normal and revert to E5 (which ain't great but it's better). Fuel stabiliser does nothing as the ethanol is still present and will absorb water if kept in the bike for long periods. For storage drain it down and put a few litres of alkylene fuel (such as Aspen) in it.
