Road bike gearing 11/28 vs 11/32
formula400
Has thanked: 444 times
Been thanked: 863 times
Post by formula400 »
Right guys, just about to pull the plug and buy a Dolan Tuono road bike. I’ve got a choice of gearing 11/28 or 11/32
I’ll be riding around Surrey, Epsom, Dorking and box hill. I am no pro, what should I got for??? My current bike is a canyon road lite 6 and has 11/34
https://www.canyon.com/en-gb/hybrid-bik ... ection-tab
So what’s a good choice??
Thanks
CBR650r :mrgreen:
Has thanked: 5455 times
Been thanked: 13103 times
Re: Road bike gearing 11/28 vs 11/32
In simple terms, if you go 11/28 the gaps between gears are slightly less... if you want a bit more climby, you want the 32... i can't see any reason to not go 32 in honesty..
Been thanked: 4125 times
11/32 will give you lower low gears and the same high gears, only thing to be aware of is the chain has to move further when you change gear compared with closer ratios
formula400
Sort of what I was thinking, just needed some reassuring
Done.
Thanks
CBR650r :mrgreen:
