TRACK WEAPON: TWO-STROKE KTM 300 FRAMER
- Has thanked: 5455 times
- Been thanked: 13103 times
https://www.bikebound.com/2020/10/02/ktm-framer/
Somethnig different was the request yesterday... so here it is
- Has thanked: 6382 times
- Been thanked: 4770 times
Re: TRACK WEAPON: TWO-STROKE KTM 300 FRAMER
Oh look! Countersteering.weeksy wrote: ↑Wed Sep 01, 2021 7:13 am https://www.bikebound.com/2020/10/02/ktm-framer/
- Been thanked: 7543 times
Why is the engine mounted so high in the frame that they've had to put CF infills under the engine to hide the gap. The rear engine mounts looks like they're a brackets taken from the swingarm pivot?
- Has thanked: 1947 times
- Been thanked: 1292 times
So they had enough ground clearance for the exhaust ?KungFooBob wrote: ↑Wed Sep 01, 2021 8:17 am Why is the engine mounted so high in the frame that they've had to put CF infills under the engine to hide the gap. The rear engine mounts looks like they're a brackets taken from the swingarm pivot?
- Been thanked: 4125 times
I like it, paintwork is a bit too black for my taste, but it looks like fun.
The engine is mounted that high to get the swingarm in the right place, the swingarm pivot runs through the crankcases.
but what's the bit that seems to link the pivot with one of the side cover bolts?
I don't know, could be to stop the pivot nut coming undoneKungFooBob wrote: ↑Wed Sep 01, 2021 9:01 am but what's the bit that seems to link the pivot with one of the side cover bolts?
- Has thanked: 2554 times
- Been thanked: 6262 times
Looks like a fairly insubstantial bit of plastic doesn't it? I think Cheesy is right.
- Has thanked: 10280 times
- Been thanked: 6892 times
Just checked mine and he's rightLe_Fromage_Grande wrote: ↑Wed Sep 01, 2021 8:54 am I like it, paintwork is a bit too black for my taste, but it looks like fun.
Enduro bikes run a high exhaust.Jody wrote: ↑Wed Sep 01, 2021 8:42 amSo they had enough ground clearance for the exhaust ?KungFooBob wrote: ↑Wed Sep 01, 2021 8:17 am Why is the engine mounted so high in the frame that they've had to put CF infills under the engine to hide the gap. The rear engine mounts looks like they're a brackets taken from the swingarm pivot?
- Has thanked: 15993 times
- Been thanked: 10261 times
Looks like its built for a purpose and achieves that too. Wish someone would be a TDM type roadster out of one though.
- ogri
- Has thanked: 1038 times
- Been thanked: 225 times
Nice, needs a bigger fuel tank though
Ignorance is bliss
- Has thanked: 2636 times
- Been thanked: 1523 times
No, drifting. Quite different!
I know Spin, I was teasing.
And I was just putting the flames out before they got going properlyCount Steer wrote: ↑Wed Sep 01, 2021 1:39 pmI know Spin, I was teasing.
- Has thanked: 9845 times
- Been thanked: 10157 times
That looks like it would flick you like a snotter.
Nice work.
Nice work.
- Has thanked: 1350 times
- Been thanked: 1730 times
- Has thanked: 6202 times
- Been thanked: 5090 times
The Spin Doctor wrote: ↑Wed Sep 01, 2021 1:50 pmAnd I was just putting the flames out before they got going properly
