deBolex dB25
- Been thanked: 7543 times
deBolex dB25
https://debolex.co.uk/db25/overview/
I kind of like it.
They've fully faired a 1200 Monster in a retro stylee.
It's a bit spendy at £38k tho'
I kind of like it.
- Has thanked: 9845 times
- Been thanked: 10157 times
Re: deBolex dB25
38k?
De Bolex is what they'd have you by.
Not bad though,quite like an up to date Rickman.
- G.P
- Has thanked: 2029 times
- Been thanked: 1310 times
- Has thanked: 498 times
- Been thanked: 650 times
Re: deBolex dB25
I don't like the bellypan. I'd probably rather have a factory Monster. The fuel cell sounds interesting though even though I'm not totally sure what they're offering there.
- DefTrap
- Has thanked: 2267 times
- Been thanked: 2193 times
Re: deBolex dB25
I preferred some of their earlier bikes. A custom bike needs to look more custom iyswim.
- Been thanked: 4125 times
- Has thanked: 2554 times
- Been thanked: 6262 times
Re: deBolex dB25
I think they mean it's got a race car style bag for the fuel, inside the carbon 'tank'. It means the tank bodywork doesn't have to be water (or more accurately petrol I suppose) tight.Asian Boss wrote: ↑Thu Aug 26, 2021 10:47 pm . The fuel cell sounds interesting though even though I'm not totally sure what they're offering there.
Re: deBolex dB25
Any idea where I could get one of them, ideal solution for tanks with internal rust.Mr. Dazzle wrote: ↑Fri Aug 27, 2021 8:23 amI think they mean it's got a race car style bag for the fuel, inside the carbon 'tank'. It means the tank bodywork doesn't have to be water (or more accurately petrol I suppose) tight.Asian Boss wrote: ↑Thu Aug 26, 2021 10:47 pm . The fuel cell sounds interesting though even though I'm not totally sure what they're offering there.
Re: deBolex dB25
ATL here in MK.
They make them for NASA and F1 teams though. They do loads of off the shelf designs too, but they tend to he cube shaped.
- Has thanked: 6382 times
- Been thanked: 4770 times
Re: deBolex dB25
That's an interesting technical problem. Touratech sell fuel bladders to carry spare fuel on stuff like the Dakar so I guess suitable material is available if you can make the necessary connections. It wouldn't need to conform to the tank interior exactly - if you accept a loss of volume you could space fill around with something like vermiculite - lightly bonded to maintain the void space? That would keep the bag away from the rusty bits too.Le_Fromage_Grande wrote: ↑Fri Aug 27, 2021 8:25 amAny idea where I could get one of them, ideal solution for tanks with internal rust.Mr. Dazzle wrote: ↑Fri Aug 27, 2021 8:23 amI think they mean it's got a race car style bag for the fuel, inside the carbon 'tank'. It means the tank bodywork doesn't have to be water (or more accurately petrol I suppose) tight.Asian Boss wrote: ↑Thu Aug 26, 2021 10:47 pm . The fuel cell sounds interesting though even though I'm not totally sure what they're offering there.
I think the ATL materials are only guaranteed for 5 years so you'd probably need to be able to swap the bladder out every once in a while.
Probably not a big market though.
Re: deBolex dB25
I don't need the 18 litres the tank on the Kawasaki holds, 10 would be plenty, but it's far from cube shaped as the frame runs down the middle of the tank, otoh both my FZ750 and FZR400 have roughly elongated cube shaped tanks.
Re: deBolex dB25
ATL do make non cube stuff, it just costs a lot more!
You can buy their roughly cube shaped cells/tanks off the shelf when you're building a rally car or whatever. I.e. a tank you can just plonk where the back seats used to be and which conforms to FiA crash regs etc.
F1 etc. uses stuff which is fitted precisely to the inside of the chassis for maximum space efficiency. F1 is famous for being cheap of course.
Re: deBolex dB25
It would probably be cheaper to get the existing tank cut open, all the rust removed, repaired and welded back up again, I was quoted "about £200" for this a couple of years ago, never got round to it because I have a spare tank for it.
