Rattle guns
- Trogladyte
- Has thanked: 68 times
- Been thanked: 89 times
Rattle guns
I've never used one, but am going to, as there are applications where I need one - notably removing and re-fitting clutch centre nuts, where you haven't got the holding tool.
When I was racing with the boy, I used a holding tool and a breaker bar to get them off, and a torque wrench to get them back on. But I struggled once or twice and the mechanics off one of the teams helped me out.
They used a rattle gun to whiz them of, and back on, and made short work of it.
My question is, if you are using them like this, how do you know you are using enough torque. These nuts had to be tight. Like really tight! But on some applications you'd be in danger of damaging parts if you apply brutal torque.
So how do you know what's tight enough, with these things?
- Has thanked: 10263 times
- Been thanked: 6885 times
Re: Rattle guns
I noticed watching the MotoGP that all teams use an old fashioned torque wrench.
Surely a good rattle gun will do it?
- MrLongbeard
- Has thanked: 599 times
- Been thanked: 2430 times
Re: Rattle guns
Only ever use them to remove nuts / bolts, if the application requires torquing back up then use a torque wrench
Re: Rattle guns
F1 use them???MrLongbeard wrote: ↑Tue Aug 17, 2021 2:04 pm Only ever use them to remove nuts / bolts, if the application requires torquing back up then use a torque wrench
Re: Rattle guns
I used to use one when I worked in a lawn mower factory 30 odd years ago for putting the blades on rotary mowers, you pretty soon got a feel for how tight to use them and then finish off with a torque wrench.
- Has thanked: 705 times
- Been thanked: 701 times
Re: Rattle guns
Those guns have a programable torque sensor and cost significantly more that I suspect Trog wants to pay- even the version available to mere mortals from Demon Tweeks is £6k....Yorick wrote: ↑Tue Aug 17, 2021 2:09 pmF1 use them???MrLongbeard wrote: ↑Tue Aug 17, 2021 2:04 pm Only ever use them to remove nuts / bolts, if the application requires torquing back up then use a torque wrench
- MrLongbeard
Re: Rattle guns
F1 use a specific gun set designed for a specific task at a specific torque and cost ten of thousands of pounds per gun.Yorick wrote: ↑Tue Aug 17, 2021 2:09 pmF1 use them???MrLongbeard wrote: ↑Tue Aug 17, 2021 2:04 pm Only ever use them to remove nuts / bolts, if the application requires torquing back up then use a torque wrench
Halfords special windy guns they ain't.
- Has thanked: 9819 times
- Been thanked: 10144 times
Re: Rattle guns
Same here. I've a DeWalt thingy for loosening.MrLongbeard wrote: ↑Tue Aug 17, 2021 2:04 pm Only ever use them to remove nuts / bolts, if the application requires torquing back up then use a torque wrench
Get the holding tool,Trog and torque it up by hand.
- Has thanked: 836 times
- Been thanked: 1238 times
Re: Rattle guns
I'm not sure my home compressor driven one would have the power to do them up with confidence. It does get them off but can take it's time so I wouldn't trust it for tightening let alone to a specific torque.
Re: Rattle guns
I was badly relating it to my question on Motogp useNidge wrote: ↑Tue Aug 17, 2021 2:39 pmThose guns have a programable torque sensor and cost significantly more that I suspect Trog wants to pay- even the version available to mere mortals from Demon Tweeks is £6k....Yorick wrote: ↑Tue Aug 17, 2021 2:09 pmF1 use them???MrLongbeard wrote: ↑Tue Aug 17, 2021 2:04 pm Only ever use them to remove nuts / bolts, if the application requires torquing back up then use a torque wrench
- Has thanked: 2550 times
- Been thanked: 6244 times
Re: Rattle guns
F1 use 'em almost entirely for the speed, which just isn't a factor a in a pit-stop free MotoGP race. You're not gonna fork out thousands for fancy windy guns when a torque wrench at 1/10th or 1/100th the cost works pretty much as just as well.
I say "almost entirely" 'cause I imagine F1 wheels are done up a fair bit tighter than MotoGP. It's gonna be ~500Nm, which is possible to undo by hand with a big bar but windy guns make it easier.
Plus the fact F1 wheels have captive nuts (i.e. the nut comes off with the wheel) and special hubs which still retain the wheel a bit if the nut isn't there, whereas MotoGP doesn't (I think?) - so the gun/socket combo is highly non-standard to make all that work.
- Been thanked: 2615 times
Re: Rattle guns
Count the duggas, one for tight, two for very tight, three for effing tight and four for ever.
- Has thanked: 65 times
- Been thanked: 1235 times
Re: Rattle guns
Once the ft-lb goes over 50, it's all academic really!
Don't clutch centre nuts have a lock on them anyhooo!
Front sprocket nuts are my favourite things for Mr windy
- Has thanked: 484 times
- Been thanked: 1427 times
Re: Rattle guns
Recently did an engine swap in one of my vans and having even the cheap Chinese copy guns made the job a breeze.
- Bigyin
- Has thanked: 1412 times
- Been thanked: 2680 times
Re: Rattle guns
The rear wheel nut on the single sided Ducati is set to 230nm by the factory. To get that off i have a 2 foot breaker bar and a 5 foot scaffold pole over it .... to do it up i pull it F tight as it hasnt fallen off yet.
The Ducati forums are chock full of "which rattle gun is the best" threads as its the easiest way to shift the rear wheelnut. Funners has a DeWalt one he thinks is brilliant and spins it off in seconds with no grief. Most of the other recommendations are for Milwaukee or Clarks
To remove the front sprocket nut of the 600 fazer i couldnt get in to get leverage with the sockets i had and didnt have the big breaker bar to hand as it was on the lift at the training base so borrowed my eldest stepsons Dewalt Impact driver and it spun it off right away
Re: Rattle guns
I know it's tongue in cheek, but I should point out this usually isn't true
The Ducati wheel as above is a good case in point. It's not done up mega tight to stop it undoing, it's done up mega tight 'cause that's how much clamp force you need. Bolts typically work by squashing the two surfaces together, it should be friction driving the load from the hub into the wheel. I.e. the bolt should be purely in tension. Since said Ducati only has one bolt you need to do it up naffing tight to get sufficient clamp force. Incidentally that's part of the reason cars/VFRs have multiple wheel bolts, you can get the required clamp with more bolts done up looser. It's also cheaper and has redundancy.
Generally if someone is speccing a big torque it's for good reason.
However that said, I do agree it is often pretty academic and I wouldn't worry about the difference between 30, 40 and 50Nm in a lot of contexts either. Not every context though
Re: Rattle guns
The lynx helicopter tail rotor hub nut is torqued to 440Nm, to get that off was a 4 man job. 2 people hanging off 2 trail rotor blades to stop them turning, 1 to hold the socket in place and one fat bloke (usually me) hanging off the 5 ft TQ wrench with full body weight.Mr. Dazzle wrote: ↑Tue Aug 17, 2021 4:02 pm
It's a bastard of a job
Re: Rattle guns
I've mentioned it before, but...
If you buy a modern Porsche with centre lock wheels (i.e. one nut) you get a special socket that goes in a little cubby under the bonnet. That's great and all, it means you've always got the special tool with you. What's less great is the fact that the wheels are done up to 450Nm, so no bugger is gonna be using that socket at the side of the road anyway
Re: Rattle guns
Especially when they find the last tyre fitter forgot to put it back.Mr. Dazzle wrote: ↑Wed Aug 18, 2021 8:38 am I've mentioned it before, but...
