Coolant, are they all the same?
First ride of the year saw my radiator developing a hole l, anyway I've removed it and hopefully it's getting repaired. I'll obviously be filling with new coolant. Are there any particular products that are better than others? Bike is a street triple which does seem to run a little hot.
- Been thanked: 9455 times
Re: Coolant, are they all the same?
There main types.
OAT
Glycol
Water
You don't want water because it freezes in the winter, expands and destroys stuff.
You shouldn't mix OAT and Glycol.
So... read your owners manual or speak to the stealership and ask which type you should use.
From an 'is one brand better than the next?' point of view.
No idea.
OAT
Glycol
Water
No idea.
- Has thanked: 602 times
- Been thanked: 4527 times
Use whatever your manufacturer recommends, they aren't all the same, and some are better quality than others.
Hairybiker84
- Has thanked: 69 times
- Been thanked: 108 times
I had issues with my Daytona 955i, really picky on coolant level and didn't take much persuasion to disgorge the header tank contents all over the floor. Changed the coolant to Evans (using the correct flushing fluid) and that was the end of the problem.
- Has thanked: 2273 times
- Been thanked: 2654 times
I use propylene glycol, engine runs 20deg cooler than with the ethylene variety. We also use it in RR Merlins. Sta-Clean brand intended for marine & big rig use.
- Druid
- Has thanked: 351 times
- Been thanked: 1106 times
My Speed Triples have been very fussy about coolant levels, anything above the minimum and it would spit coolant out. Must be a Triumph thingHairybiker84 wrote: Mon Aug 02, 2021 3:39 pm I had issues with my Daytona 955i, really picky on coolant level and didn't take much persuasion to disgorge the header tank contents all over the floor. Changed the coolant to Evans (using the correct flushing fluid) and that was the end of the problem.
- DefTrap
- Has thanked: 1838 times
- Been thanked: 1468 times
You've just reminded me that at least two of my vehicles need a coolant change, so thanks!
Mine too. It's got the second tank under the seat, it's never happy unless that tank is empty!Druid wrote: Tue Aug 03, 2021 8:04 amMy Speed Triples have been very fussy about coolant levels, anything above the minimum and it would spit coolant out. Must be a Triumph thingHairybiker84 wrote: Mon Aug 02, 2021 3:39 pm I had issues with my Daytona 955i, really picky on coolant level and didn't take much persuasion to disgorge the header tank contents all over the floor. Changed the coolant to Evans (using the correct flushing fluid) and that was the end of the problem.
Try removing the pressure cap and cleaning both the rubber seals and seats. There's usually some black flakes of paint or powder coat stuck to them, which leads to leaks under pressure (i.e. when hot).Mr. Dazzle wrote: Tue Aug 03, 2021 9:31 amMine too. It's got the second tank under the seat, it's never happy unless that tank is empty!Druid wrote: Tue Aug 03, 2021 8:04 amMy Speed Triples have been very fussy about coolant levels, anything above the minimum and it would spit coolant out. Must be a Triumph thingHairybiker84 wrote: Mon Aug 02, 2021 3:39 pm I had issues with my Daytona 955i, really picky on coolant level and didn't take much persuasion to disgorge the header tank contents all over the floor. Changed the coolant to Evans (using the correct flushing fluid) and that was the end of the problem.
