(Carbed) CBR600 flat spot/hesitation
- Has thanked: 2550 times
- Been thanked: 6244 times
My day-to-day bike appears to have a massive power hole (or whatever you call the opposite of a power band ) at certain rpm / throttle combos.
Specifically, it really struggles to get 'through' 7-8kprm in a lot of situations. Riding home today it wouldn't actually get past 8krpm at all in top gear. I could sit at ~85mph with the throttle wide open and it would just hit a wall. Changing down to bring the revs up solved it immediately and it pulled strongly after that. Tucking in behind the fairing (and hence reducing the power needed to go faster) had the same effect. If you're accelerating and 'pass through' that rev range it's OK, but if you're already at 7kprm it won't pull. Which is really annoying, 'cause that's motorway speed!
The bike is pretty much stock 1998 CBR600 except for a K&N filter and dyno jet kit fitted by a previous owner. TBH due to work and various other things I've not ridden it much at all lately so I'm not sure if it has been doing this forever or it's a new thing.
It feels like a carb thing though surely? No other engine problems, will pull to the redline strongly above/below that speed and otherwise runs just fine.
Ideas?
Ideas?
- Has thanked: 5450 times
- Been thanked: 13085 times
Re: (Carbed) CBR600 flat spot/hesitation
It wouldn't get to full power? The problem is just 'passing through' IYSWIM? I'm not sure where the filter is.
I just say carbs 'cause the fact it occurs mid-revs implies it's on the transition between jets?
- Been thanked: 7526 times
That's exactly what a fuel filter issue feels like, honestMr. Dazzle wrote: ↑Wed Jul 14, 2021 8:39 pmIt wouldn't get to full power? The problem is just 'passing through' IYSWIM? I'm not sure where the filter is.
Ducatis, gsxrs, etc. Not sure about Honda's, not owned any
It's an inline jobby by the looks of it (#4)...probably not too hard to get at. Touch wood Actually thinking back, I think I might have seen it last time I took the fairing off....
EDIT: Oh and I recently ran out of fuel (within rolling distance of a petrol station!) so maybe that made me suck some crap up?
It's a cheap and simple one as a first port of call. It'll have an arrow on it, make sure the arrow is the same way (assuming that one is correct of course)
I doubt I'd have got the last few thousand miles on it if the current filter was in backwards.
- Has thanked: 15949 times
- Been thanked: 10243 times
If you're not sure it was ever set up right, then you need to check the settings are right. You should be able to find the advised settings for the DJ kit online. You're on the needle/main jet circuits there, so you're easiest and first port of call should be to check the needle height is where it should be and next would be the PITA of checking what main jets are in there. K&Ns don't flow any more, and some times less, than OEM filters, but people used to think they did and set up DJ kits wrongly based on that belief.
You summed it up nicely with PITA. I've got enough of those ATM
But the fuelling doesn't work properly. You'll need more than £500 to get it ablaze!
If you do take the carbs off, remove the float valve as they have a little mesh filter behind there which never gest cleaned and often gets gummed up.
Honestly not sure....
This bike came to me with the Bonneville in late 2019 and its been my "day bike" ever since following some garage consolidation. I've not ridden it much over the last few months.
Previously I didnt do much "trolling along at 7000rpm in top on part throttle" 'cause that's basically motorway riding. I have only just started commuting again and hence using motorways again.
- Tricky
- Has thanked: 2564 times
- Been thanked: 2680 times
This would be my approach after draining the float bowls in case there is a bit of water in one and then changing the plugs if that doesn't change anything- I had exactly this sort of scenario twice with my (FI) ZX10R twice after it had been lying around unused for 6 months or so- ended up being one very low milage (NGK iridium) plug gone bad each time.Taipan wrote: ↑Thu Jul 15, 2021 7:46 am If you're not sure it was ever set up right, then you need to check the settings are right. You should be able to find the advised settings for the DJ kit online. You're on the needle/main jet circuits there, so you're easiest and first port of call should be to check the needle height is where it should be and next would be the PITA of checking what main jets are in there. K&Ns don't flow any more, and some times less, than OEM filters, but people used to think they did and set up DJ kits wrongly based on that belief.
And if you do end up with the carbs off, alongside what Tiepin says, also have a good look at the emulsion tubes (the brass tubes that the slide needles travel up and down in)- dependent upon how many miles they've been in there, and who they are made by, they wear- basically eventually go a bit oval- which manifests as exactly these symptoms
" Factory" (a direct competitor to Dyno-Jet- produced the same sort of carb-correction kits) emulsion tubes were notorious for doing this after next to no miles at all in some bikes
- Has thanked: 9825 times
- Been thanked: 10144 times
Carbs at an angle tend to wear the emulsion tubes,as Tricky said.
ZZR1100s used to get a shiny wear mark on one side of the needles.
Incidentally on the ZZR I had a similar problems as the CBR which was caused by a loose needle on one carb. Man it took many stripdowns to find that bastard. The wear marks flagged it up.
I remember when EFI first started becoming common, everyone hated the fact you 'couldn't fix it at the side of the road'.
'tis true. But you don't have to strip down a load of fiddly bloody screws either!
I'd start with the easy and gradually get to the harder stuff
1. Give it a good thrashing
2. Change fuel filter
3. Check pump is pumping
4. Take the airbox off and squirt carb cleaner everywhere
5. Take the carbs off strip, inspect and clean
I suspect it's worn needles though, Dynojet needles aren't very good
Already done number 1, as far as is sensible on the road.
P.S. I'll probably just get OE Honda bits if the needles etc. need replacing. It's not like I need that extra (claimed) 4% of power in this bike.
