1977 Yamaha TZ750
- Has thanked: 5504 times
- Been thanked: 12764 times
- Has thanked: 2000 times
- Been thanked: 1275 times
- Has thanked: 264 times
- Been thanked: 1242 times
- Has thanked: 2636 times
- Been thanked: 1498 times
Re: 1977 Yamaha TZ750
It's got low mileage tyres though!
- Has thanked: 626 times
- Been thanked: 4072 times
It's very original and very expensive, I'd like a go on one just to see what they're like, I reckon it's going to be about 130bhp as a TZ350 is about 65bhp, the power delivery will probably be interesting.
Though I doubt if that one runs as it should, the crank seals have probably gone hard and no longer seal
- Has thanked: 1452 times
- Been thanked: 1335 times
The bigger issue is the crankcases were of cheese & are likely to be warped all to hell. Someone in the US(?) started making new cases for them a few years ago.Le_Fromage_Grande wrote: ↑Mon Jul 12, 2021 10:37 am It's very original and very expensive, I'd like a go on one just to see what they're like, I reckon it's going to be about 130bhp as a TZ350 is about 65bhp, the power delivery will probably be interesting.
It doesn't look like it's been run since 1976, I doubt if the crankcases warp with no use.
- Has thanked: 9691 times
- Been thanked: 9706 times
Fook.
There's some asking money for old race stuff,isn't there. I wonder what it'll actually fetch.
A few years ago I watched a mate spanner Tom Herron's old TZ750 for a parade run around the Dundrod UGP circuit. Another friend was Herron's team mate for a while and he got to ride the bike. It looked a lot easier to work on than any modern superbike!
They're easy to work on, they're basically two TZ350 engines joined at the hip, if you can rebuild an LC, you can rebuild a TZ, but the good race engines are made up from carefully matched parts.Skub wrote: ↑Mon Jul 12, 2021 4:27 pm Fook.
I should weigh my two brand new YPVS pistons to see how much difference there is in the weight of them, not that it matters on that bike because I haven't weighed the crank components.
Unless that's why it was parked...Le_Fromage_Grande wrote: ↑Mon Jul 12, 2021 4:15 pm It doesn't look like it's been run since 1976, I doubt if the crankcases warp with no use.
I hadn't thought of thatZRX61 wrote: ↑Wed Jul 14, 2021 1:38 amUnless that's why it was parked...Le_Fromage_Grande wrote: ↑Mon Jul 12, 2021 4:15 pm It doesn't look like it's been run since 1976, I doubt if the crankcases warp with no use.
