Disabling DataTool S4
Champy72
Been thanked: 3 times
Post by Champy72 »
Not sure if this is the correct location to post this, but I have been looking around for hints and tips on how to disable/remove the DataTool Alarm easily. :?:
I am not a lover of alarms - believing an immobiliser and quality chain works just as well - and there are so many reports of batteries draining and upsetting the neighbours with a false trigger. :thumbdown:
I am picking up a Speed Twin which has an S4 version, and even the guy selling it recommends that it be removed!
So. Looking around it does seem fairly straight forward with some good videos.
The S4 looks like unplugging the white socket from the Triumph loom and cutting all the wires from the alarm side of this socket, and then shorting terminals 1 & 2, and 3 & 5, before reconnecting the plug back into the loom. :thumbup:
I would assume the alarm is set to Winter or some such before starting! :shock:
Of course, if cutting/shorting wires is not your cup of tea, you can buy a replacement plug already made up for around £20...
There is also a video of disabling an S3 version, which seems to be slightly different.
Hope this may help. Let me know if you would like the video links...
Has thanked: 5450 times
Been thanked: 13085 times
Re: Disabling DataTool S4
Where you based? I know a mobile guy who'd do it for about £100 in Surrey
Has thanked: 599 times
Been thanked: 2436 times
If it's a trumpet as you say then for the S3, it was just unplug the alarm and plug in the blanking plug, no cutting, no shorting, nice n simple like.
Has thanked: 1346 times
Been thanked: 1722 times
Then throw the bugger on a fire so it doesn't torture anyone else.
Champy72
Post by Champy72 »
weeksy wrote: Sat Jul 10, 2021 11:04 am Where you based? I know a mobile guy who'd do it for about £100 in Surrey
I'm in Essex, but I wouldn't pay anything to get it sorted - too easy to do it yourself!
636mick
Has thanked: 1079 times
Been thanked: 720 times
Post by 636mick »
As MrLongbeard said, if it’s a Triumph badged alarm but an S4, then it’s a case of unplug, plug in the correct blanking plug and it’s done.
Mick.
