Turntable
iansoady
Has thanked: 59 times
Been thanked: 169 times
Turntable
Post by iansoady »
I'm having trouble with an arthritic hip so have just bought a Yamaha X-max 250 "maxi-scoot". The layout of my garage / drive means that i go into it forwards but want to exit in the reverse direction so want to rotate the bike to point the other way. I did manage this with a 90 point turn the other day but felt there must be a better way.
I've seen people build small turntables using a lazy susan type bearing like this:
Anybody here tried something of this type?
r1flyguy
Has thanked: 70 times
Been thanked: 79 times
Re: Turntable
Post by r1flyguy »
What we need is a mini version of this :)
https://www.ukturntables.com/diy-car-turntables/
Has thanked: 836 times
Been thanked: 1238 times
Re: Turntable
Smaller scooter?
Does it have a side stand?
PitaNaanRoti
Has thanked: 25 times
Been thanked: 54 times
Re: Turntable
Post by PitaNaanRoti »
There’s a guy on the UKGSeR forum who makes them - about £50
iansoady
Re: Turntable
Post by iansoady »
That car one's too big. Yes it has a side stand. 250 is as small as I want to go (and actually smaller wouldn't solve the problem). Oh, and I'm a cheapskate so total cost must be < £50 (a lot less if possible).
Don't know what happened to my link: https://www.amazon.co.uk/SUSAN-TURNTABL ... B007U6CWNU
iansoady
Re: Turntable
Post by iansoady »
PitaNaanRoti wrote: Sat Jul 03, 2021 11:20 am There’s a guy on the UKGSeR forum who makes them - about £50
Replied before I saw this - may have a look if they'll let me in.
I did find this thread which is probably similar (or even the same bloke): https://www.thetriumphforum.com/threads ... ble.22871/
Re: Turntable
iansoady wrote: Sat Jul 03, 2021 11:40 am That car one's too big. Yes it has a side stand. 250 is as small as I want to go (and actually smaller wouldn't solve the problem). Oh, and I'm a cheapskate so total cost must be < £50 (a lot less if possible).
Have you tried pivoting it round on the stand? If it works you probably just need a puck so it doesn't make a hole in the floor.
iansoady
Re: Turntable
Post by iansoady »
Ah, but that might make a hole in the carpet.....
The reason I got the X-max was my arthritic hip and advancing senility which makes anything involving lots of effort not a good plan.
PitaNaanRoti
Re: Turntable
https://simplybearings.co.uk/shop/
Add a 3mm plate t the top
iansoady
Re: Turntable
Post by iansoady »
Yes, seen them. I was thinking about mdf for the top plate.
Has thanked: 2550 times
Been thanked: 2285 times
Re: Turntable
iansoady
Re: Turntable
Post by iansoady »
Yes, that might be worth a thought. Or I could even make one......
Has thanked: 143 times
Been thanked: 497 times
Re: Turntable
Post by Silly Car »
https://www.toolstation.com/roughneck-dolly/p54166
You could always shorten the board if needed.
Re: Turntable
Careful with the wheel sizes, too small and you need a perfectly smooth hard floor but too big and you won't get the scooter on it. CJ's link looks good if your floor is suitable.
maccecht
Has thanked: 24 times
Been thanked: 156 times
Re: Turntable
Post by maccecht »
I have a similar issue but it is due to getting bikes in and out of my Garden. Lazy Susan with a piece of 5mm steel plate affixed to it with tek screws allows me to turn the bike 180. This is using it to turn my GS 1200. Sorry about the fat ugly bloke in the vid 😁
https://www.dropbox.com/s/cqitac083trjw ... 8.mp4?dl=0
Has thanked: 9825 times
Been thanked: 10144 times
Re: Turntable
maccecht wrote: Sat Jul 03, 2021 8:24 pm I have a similar issue but it is due to getting bikes in and out of my Garden. Lazy Susan with a piece of 5mm steel plate affixed to it with tek screws allows me to turn the bike 180. This is using it to turn my GS 1200. Sorry about the fat ugly bloke in the vid 😁
I bet you're not really sorry at all. :(
maccecht
Re: Turntable
Post by maccecht »
Skub wrote: Sat Jul 03, 2021 8:48 pm
Regretfully you are indeed correct 👍
iansoady
Re: Turntable
Post by iansoady »
That makes it look very easy. Lots of possibilities here - many thanks for all.
Has thanked: 6187 times
Been thanked: 5087 times
Re: Turntable
Does that rely at all on the GS's balance point about the centre stand?
maccecht
Re: Turntable
Post by maccecht »
Horse I just push thd back end down to get the front wheel up and spin it very little effort needed. Will post some pics up of the lazy Susan and plate.
As noted the centre stand sits on the plate
