Getting Old Bar Grips Off?
- Has thanked: 10263 times
- Been thanked: 6885 times
It appears that the grips on the mighty Husky have been glued on. After 10 moments cursing and swearing, the buggers still won't come off.
Is there a secret way ?
Do I need to buy new tubes?
What's for tea?
What's for tea?
- Has thanked: 326 times
- Been thanked: 2173 times
Re: Getting Old Bar Grips Off?
We sometimes use compressed air with a small hose attachment. Normally works well
These buggers have been put on with some good glue. No way to get air in.
- Been thanked: 2616 times
What solvents do you have to hand, or can get? Any of those might be worth a try. Probably easier buying a new throttle tube.
Acetone would be one of the first I'd try, somewhere that sell fibreglass might have it.
- DefTrap
- Has thanked: 2259 times
- Been thanked: 2191 times
- Been thanked: 7526 times
You need to buy new.
That bike is obviously well used, you need a newer one with nice new grips.
Cut them off with a Stanley knife, it's not like you're going to use them again
Tried that. Glued all over.Le_Fromage_Grande wrote: ↑Thu Jul 01, 2021 8:54 pm Cut them off with a Stanley knife, it's not like you're going to use them again
New bike next year.KungFooBob wrote: ↑Thu Jul 01, 2021 8:50 pm You need to buy new.
- Has thanked: 7814 times
- Been thanked: 2527 times
If it were mine, I'd buy a new throttle tube (or try to find a 2nd hand one), but cut the left side off as best as possible with a sharp knife. If they're as badly glued as they look then getting the new grip on the throttle tube is going to be awkward unless you get all the glue off cleanly, but with the left one you can be a bit more forceful when you put the new grip on.
- Has thanked: 261 times
- Been thanked: 1265 times
Finally got them cleaned and new grips fitted.
Then my pal says they come as a set.
https://www.odigrips.com/collections/mo ... grips-2723
- Screwdriver
- Has thanked: 256 times
- Been thanked: 740 times
Integrated part. That's a one piece design. Probably not glued but solvent weld.
I know that nowScrewdriver wrote: ↑Fri Jul 09, 2021 10:51 pm Integrated part. That's a one piece design. Probably not glued but solvent weld.
Those bark busters have seen some action considering you don't have any trees :p
I just chuck it at the scenery willy nilly.KungFooBob wrote: ↑Sat Jul 10, 2021 11:29 am Those bark busters have seen some action considering you don't have any trees :p
