SUZUKI GS850 CAFÉ RACER BY MCAFEGARAGE
- Has thanked: 5504 times
- Been thanked: 12764 times
- DefTrap
- Has thanked: 2269 times
- Been thanked: 2088 times
Re: SUZUKI GS850 CAFÉ RACER BY MCAFEGARAGE
Quite like that, a GS made better, you don't see that very often.
- Has thanked: 2634 times
- Been thanked: 1498 times
Yay! Side panels and a proper seat!
Nay! No mudguards
Nay! No mudguards
- Has thanked: 626 times
- Been thanked: 4072 times
- Has thanked: 1788 times
- Been thanked: 1408 times
- Has thanked: 532 times
- Been thanked: 7241 times
- Has thanked: 1452 times
- Been thanked: 1334 times
There's a former London m/c despatcher here that has one with a '75 Kaw Z1-B paint job on it, albeit the wrong colors, it's mostly silver. He's owned it for at least 25 years.
Look like standard early GS1000 carbs, early GS850s may have had the same carbs, they're relatively easy to get running on pod filters.
I hadn't spotted that... bit silly. And not great in sidewinds, I believe. The old Banana Comstars on Hondas were a bit of a mare when the wind blew.
Yes, they look like the Mikuni VM26s fitted to my 750, iirc the GS1000 used VM29s. I thought the 850 used CV carbs as standasd though.Le_Fromage_Grande wrote: ↑Fri Jul 02, 2021 3:19 pmLook like standard early GS1000 carbs, early GS850s may have had the same carbs, they're relatively easy to get running on pod filters.
- Has thanked: 223 times
- Been thanked: 842 times
The 850 and 1000 shafties both used CVs on UK bikes.Druid wrote: ↑Fri Jul 02, 2021 11:40 pmYes, they look like the Mikuni VM26s fitted to my 750, iirc the GS1000 used VM29s. I thought the 850 used CV carbs as standasd though.Le_Fromage_Grande wrote: ↑Fri Jul 02, 2021 3:19 pmLook like standard early GS1000 carbs, early GS850s may have had the same carbs, they're relatively easy to get running on pod filters.
