What pressure gauge ?
- Has thanked: 5450 times
- Been thanked: 13085 times
My pressure gauge seems rubbish doing the rear on the ZX6R and won't 'sit' right on it. Not sure if that's a fault of the valve, the user, or the gauge.
But thought i'd look into a new one just in case.
What's the recommendation ?
- Has thanked: 2941 times
- Been thanked: 1882 times
Re: What pressure gauge ?
I use my Topeak D2 mtb gauge. It's a bit fiddly to use but does the job.
Should be getting my new one tomorrow.
Will be interesting to see what it reads compared to my others, there's 3psi difference between mine, which when it comes to certain rubber these days can actually be quite a difference
- Has thanked: 9825 times
- Been thanked: 10144 times
I've always found the cheap and cheerful pen type gauges to be most reliable and accurate. I've one from the 70s which still reads the same as others more expensive!
I'm not adverse to blingy ones tho....
- MrLongbeard
- Has thanked: 599 times
- Been thanked: 2435 times
I would suggest mine (that's how this works right?), a nice heavy metal bodied Halfords jobbie, but they don't sell them any longer, it's been with me and used every week for years n years.
- Has thanked: 479 times
- Been thanked: 310 times
I recently bought a Venhill https://www.venhill.co.uk/tools/tyre-am ... -vt32.html gauge. It has a very good quality feel to it, and holds the reading until you press a valve to release the needle. Its flexible hose also makes it easy to position if correctly. Recommended - although not for carrying with you, as it's a bit heavy.
- Has thanked: 2248 times
- Been thanked: 1242 times
I've used a BluePoint Snap-On one for many years now, still accurate - https://www.snapon-bluepoint.com.sg/cat ... Tire-Gauge
Sure others are just as good though but it works well.....
- Has thanked: 1829 times
- Been thanked: 1469 times
My Topeak MTB is the most accurate - I also have a Halfords cheap digital that works well.
- Tricky
- Has thanked: 2564 times
- Been thanked: 2680 times
I've got a couple of these- have proved accurate whenever I've checked them and so much easier to use than the faffy little Halford type battery-operated jobbies
https://www.amazon.co.uk/Draper-69924-P ... th=1&psc=1
- wull
- Has thanked: 880 times
- Been thanked: 1544 times
I use a Venhill gauge which I used for racing but just the odd occasional track day now and road, it holds peak psi until you release it and allows you to bleed off excess air if needed.
Find one and stick with that, use that one across the board for accurate readings, like you say 3psi can make a difference depending on tyres riding etc.
