Electric Superbike Twente
- Has thanked: 5504 times
- Been thanked: 12764 times
https://electricsuperbiketwente.nl/superbikes/delta-xe/
https://www.bikeexif.com/motorcycle-news-june-13-2021
- Has thanked: 852 times
- Been thanked: 1226 times
Re: Electric Superbike Twente
I quite like that but I can't help thinking there will be a light bulb moment at some point with electric bikes. 'Now we don't need that central mass of an engine here's a much better way to distribute the weight.'
- Has thanked: 5945 times
- Been thanked: 4933 times
Scooter style, low-slung weight.
Also means the 'feet first' riding position is more easily achievable.
- Has thanked: 1326 times
- Been thanked: 1652 times
Think mass centralization has been the goal with conventional bikes for some time hasnt it?
Just the chubby draggy riders that are the main problem.
Having the weight too low affects traction and braking though so its a balance.
Having electric hub motors offers the option of regenerative ('engine') braking from both wheels instead of just the rear and, similarly, drive from both wheels.demographic wrote: ↑Sat Jun 19, 2021 8:33 amHaving the weight too low affects traction and braking though so its a balance.
IIRC low CoM (especially if with longer wheelbase) will reduce the likelihood of stoppies and improve rear grip for braking.
- Has thanked: 2917 times
- Been thanked: 1847 times
If it worked for Kaneda in Neo Tokyo I'll have one.......
