SALVAGE STAR: A YAMAHA VIRAGO 750 REBORN AS A CAFE RACER
- Has thanked: 5503 times
- Been thanked: 12760 times
https://www.bikeexif.com/yamaha-virago-750
Not sure why, but this one really is a yes for me... simple, basic, efficient. I approve.
- Has thanked: 532 times
- Been thanked: 7217 times
Re: SALVAGE STAR: A YAMAHA VIRAGO 750 REBORN AS A CAFE RACER
Not sure about the exhaust routing (and welding) for that front pot.
I like it, but there are dozens of these Viagra cafe racer conversions, I was impressed by the first one I saw, but now they all look the same.
- Has thanked: 2609 times
- Been thanked: 6012 times
It's probably to make it the same length as the other header? Seemingly only had access to straight pipes though.
- Has thanked: 626 times
- Been thanked: 4063 times
Oh God, I actually quite like it.
- Has thanked: 15604 times
- Been thanked: 9848 times
- DefTrap
- Has thanked: 2268 times
- Been thanked: 2086 times
Yep, there are loads of these.
I don't like the ones where the bike comes out too tall (as this one is).
It needs to be more like this (fuck know why they don't turn the lights on to get pics ffs)
or this
The red one has about a mile gap between the motor and tank, what's that all about?
or this
I must like the taller ones, as I don't like the ones DefTrap has posted, though the red one does look like a tidied up XSR700
That silver one would be ace if it had the seat off one of the other two.
- DefTrap
The XV has a great motor, mind, apart from the stoopid starter clutch problem.
- Has thanked: 2632 times
- Been thanked: 1498 times
Not sure about the dented, scraped and rusting tank.
- Has thanked: 2319 times
- Been thanked: 3373 times
First thing I notice is the dissimilar front and rear wheels. Should have used a front that matches the LC stylee rear. Is that a huge spine frame I see ? That would explain the excessive gap between motor and tank, but not the ridiculously high seat. And that exhaust welding is proper gash. OK, it's miles better than I could do, but for something like that if you can't get the bends done you need much smaller sections and better quality TIG welding. And what I presume is the oil tank is about the same quality as a 3rd year metalwork student would knock up. But it's matt black and low down so no-one will notice.
- Potter
- Has thanked: 2216 times
- Been thanked: 4610 times
I don't understand it at all, it looks shit and knocked up by someone on a very limited budget and using whatever was available from the breakers down the road even if it didn't fit and made it look shit.
Back in the day I saw loads of bikes like this knocked up by skint blokes who needed them to get to work and couldn't afford anything else.
If that's the look he's going for then he's nailed it.
I think that's exactly what he's going for with it. Which is why i like itPotter wrote: ↑Fri Jun 18, 2021 2:24 am I don't understand it at all, it looks shit and knocked up by someone on a very limited budget and using whatever was available from the breakers down the road even if it didn't fit and made it look shit.
- DefTrap
There's a decent amount of work in putting a traditional subframe on that weird pressed steel spine frame, plus there's loads of work removing all the stock gubbins and mess of airbox, let alone creating exhausts etc. Its actually quite a hard base as a start point because, other than the motor, the stock bike is a fecking ugly cruiser which gets worse the more tinwear you take off.
So I wouldn't say it was either cheap or easy but,for me, the design is flawed ...
