Degreaser, what do you use?
- Has thanked: 15614 times
- Been thanked: 9853 times
Normally use paraffin but the Mrs moans it stinks for days after. I did try the Gtechniq W5 Citrus All Purpose Cleaner but wasn't that impressed with it, but admit I could have got the ratio wrong? Anything else good out there?
- Has thanked: 7727 times
- Been thanked: 2401 times
- MrLongbeard
- Has thanked: 579 times
- Been thanked: 2289 times
- Has thanked: 532 times
- Been thanked: 7241 times
- Has thanked: 746 times
- Been thanked: 701 times
Re: Degreaser, what do you use?
I buy 5L of Screwfix "No Nonsense " heavy duty degreaser for less than a tenner and decant it into a spray bottle. Works well enough cleaning my collection of oily old Brit bikes and removes sticky chain lube well
- Has thanked: 5504 times
- Been thanked: 12764 times
- Has thanked: 4249 times
- Been thanked: 2757 times
I was using the W5 but it's still not as good as sdoc, if a lot cheaper. I also find it doesn't do much for chain lube. I tend to spray it on and go over the rear wheel with a pain brush then hose off but it's still not perfect so I wait until it's dry and use GT85 and a rag. I was diluting to about 1/4 with water.
I recently bought some of the latest muck off stuff as there was a special on 5 litres at SBS. That's ok but bit like W5 not perfect or as good as Sdoc. You apply that to a wet bike.
For chain cleaning I use paraffin if it's bad but just decant a little into a old bean pot and apply using a paint brush, that way you don't use much and it still cleans well. If it's not too bad I use GT85 and a rag.
For general wipe overs of engine/frame/swingarm etc if there's grease on them GT85 and a rag works great. Plus smells nice too.
- Has thanked: 2611 times
- Been thanked: 6015 times
I use a fair bit of paraffin on the old brit bikes, mostly 'cause that's what the Triumph manual says to use. It's got a few bits inside the engine and oil system you're supposed to clean on a regular basis, whatever you put in there theoretically might end up in the oil so I used paraffin.
Got a big bottle of generic brake cleaner which is good for little bits. It evaporates away well, which is nice. Also means you need good ventilation though! I might get some of that degreaser stuff Nidge mentioned.
I used to use the vapour degreaser at my old work somtimes, that was feckin' brilliant.
https://www.techspray.com/vapor-degreas ... m%20parts.
Hmmm, that's tempting as there is quite a lot of that hanging around here, just waiting to be borrowed...KungFooBob wrote: ↑Wed Jun 16, 2021 10:26 am Depends.
Getting chain lube off bike wheels, swingarm, etc.. WD40.
Works really well.Taipan wrote: ↑Wed Jun 16, 2021 10:45 amHmmm, that's tempting as there is quite a lot of that hanging around here, just waiting to be borrowed...KungFooBob wrote: ↑Wed Jun 16, 2021 10:26 am Depends.
- Has thanked: 9690 times
- Been thanked: 9704 times
S-doc
Chain/brake cleaner
Vulcanet wipes
WD40
Proper acetone
That's my arsenal.
Chain/brake cleaner
Vulcanet wipes
WD40
Proper acetone
That's my arsenal.
- Has thanked: 10117 times
- Been thanked: 6649 times
Stick it in the dishwasher. Then she'll stop moaning about any smell
That does look a bit of a bargain. Think i'll give it a whirl.
https://www.screwfix.com/p/no-nonsense- ... 5ltr/88668
- Has thanked: 2355 times
- Been thanked: 1218 times
I used to have access to MEK,Tric and the like when I worked in the aircraft industry. Harsh stuff on the old epidermis.v8-powered wrote: ↑Wed Jun 16, 2021 12:37 pm Used to use MEK but usually brake cleaner these days...
Back in the day we had a Tric tank big enough to fit a car inSkub wrote: ↑Wed Jun 16, 2021 12:49 pmI used to have access to MEK,Tric and the like when I worked in the aircraft industry. Harsh stuff on the old epidermis.v8-powered wrote: ↑Wed Jun 16, 2021 12:37 pm Used to use MEK but usually brake cleaner these days...
Cleaned anything from everything!
- Has thanked: 2324 times
- Been thanked: 3375 times
You can still get MEK on ebay, believe it or not...
I use (in no particular order of merit) depending on the job in hand
Jizer
Paraffin
Acetone
Brake cleaner
GT 85
White spirit
Shiny sauce
Various wipes
Jizer
Paraffin
Acetone
Brake cleaner
GT 85
White spirit
Shiny sauce
Various wipes
And don't forget the Bennetts bloke rated aldi (or was it Lidl) washing up liquid as pretty much the best cleaner/degreaser. No salt and cheaper than chips!
- Has thanked: 2632 times
- Been thanked: 1498 times
Motul Motowash is pretty good.
Worth pointing out that petrol contains a lot of nasty carcinogens.
