£20 needs attention…
- Has thanked: 15628 times
- Been thanked: 10069 times
Saw this on marketplace and bought it. It was running okay but then stopped. Fuel line was split so he replaced it and now it starts and idled but won’t Rev. Took the cover off and petrol is leaking back out from somewhere? How do I fix it?
TIA
picture hosting service
TIA
- Has thanked: 10094 times
- Been thanked: 6793 times
Re: £20 needs attention…
Buy a new one, fucking tight arse.
Folk like you give us Yorickshire folk a bad name.
- Has thanked: 1939 times
- Been thanked: 1283 times
Can't be sure without seeing it in person but I think you need to replace the flux capacitor, then it'll be reet
- Has thanked: 532 times
- Been thanked: 7408 times
Sounds like the gel packs have corrupted and blown the plasma relays, you'll have to reroute power through the main deflector.
- Has thanked: 1332 times
- Been thanked: 1680 times
Dunno about that but a while ago I got a Stihl chainsaw that needed another impulse pipe and carb diaphragm.
The impulse pipe runs from the inlet tract to the carb if I remember right and provides a bit of vacuum for the carb.
The carb didn't have a float bowl and the impulse pipe used the vacuum pulses to move the flat diaphragm.
It was a while ago and I can't remember details.
I don't even want or need it, but thought it was too much of a bargain to pass up.
- Has thanked: 5408 times
- Been thanked: 12939 times
- Been thanked: 2572 times
A complete new carb is likely about a tenner,. Fit one, it'll be easier than trying to fault find.
- Has thanked: 9690 times
- Been thanked: 9957 times
Too much power for you Lundun boi,don't fix it.
- Cousin Jack
- Has thanked: 2502 times
- Been thanked: 2217 times
Don't be silly, all it needs is a new power band. A red one will be besr, black will be overkill.
- the_priest
- Has thanked: 1874 times
- Been thanked: 2170 times
Needs bar risers and a pink paint makeover. It Essex innit??
On a more serious thought, I sorted a rotavator that had blocked jets and that was a pain. New carb is the answer as mentioned before.
Found out its an Aldi one. Will put another carb on but most of the ones I've seen in a quick scan on eBay have a plunger built in, where as the one on the strimmer doesn't. Its plunger is mounted on the upper bodywork. Ill get a model number and try mospares or suchlike.
The one that's on there looks like this...
Or work.
