Lolz inside, see through 2t cylinder head in action!
- Has thanked: 15614 times
- Been thanked: 9853 times
Fab! Oh and keep watching...
- Has thanked: 2611 times
- Been thanked: 6016 times
Re: Lolz inside, see through 2t cylinder head in action!
We had a four stroke one of them at Uni which also had transparent cylinders. ..it was mostly used to measure fuel injection patterns with a laser, so it was spun electrically and not actually running. It was perfectly capable of running properly though.
- Has thanked: 10117 times
- Been thanked: 6649 times
- Has thanked: 1326 times
- Been thanked: 1652 times
Not the same thing but sometimes engines cut in half give valuable information thats hard to visualise as well.
Decent example on oem-cycle.com showing why various reed blocks work or don't.
http://oem-cycle.com/forum/viewtopic.ph ... er+cutaway
Sometimes worth the effort to hack knackered parts up.
- Has thanked: 1452 times
- Been thanked: 1333 times
Fired up one of my Kaw triples with only two of the heads installed once
There's a reasonable vid about a drag racing H1 based thing, anyway at about 15:20 or so they show the dyno test "Mule" with a cylinder made from an aluminium block, looks proper weird cos there's no cooling fins but its not running for long enough to need em.
The presenter is kind of irritating but it's worth a watch all the same.
- Has thanked: 521 times
- Been thanked: 650 times
I saw that a few days ago. Pretty cool. Especially seeing how they made it,
Oh, those Russians! (Or Polska in this case!).
