Mushroom Plugs
- Ditchfinder
- Has thanked: 591 times
- Been thanked: 665 times
Mushroom Plugs
Managed to pick up a screw in the rear tyre yesterday - luckily only a small. Local mechanic thinks a mushroom plug repair should be OK. It's in the middle of the rear tyre ( which is only 200 miles old).
Any of you guys used mushroom plugs before? Do you trust them?
- DefTrap
- Has thanked: 2225 times
- Been thanked: 2142 times
Re: Mushroom Plugs
I have to say I still use the old fashioned diy sticky strip stuff because it's easy.
I had a mech install a mushroom plug in the distant past though because (he said) it was better.
- Has thanked: 1939 times
- Been thanked: 1283 times
Re: Mushroom Plugs
A mushroom plug fitted from the inside?Ditchfinder wrote: ↑Thu Jun 10, 2021 10:47 am Managed to pick up a screw in the rear tyre yesterday - luckily only a small. Local mechanic thinks a mushroom plug repair should be OK. It's in the middle of the rear tyre ( which is only 200 miles old).
Then yes, no problem if the hole is in the middle and not at an acute angle.
- Has thanked: 7609 times
- Been thanked: 2452 times
Re: Mushroom Plugs
Fitted by a decent mech, yes, it'll outlast the tyre. I've had exactly the same happen and plugs fitted with no issues at all.Ditchfinder wrote: ↑Thu Jun 10, 2021 10:47 am Managed to pick up a screw in the rear tyre yesterday - luckily only a small. Local mechanic thinks a mushroom plug repair should be OK. It's in the middle of the rear tyre ( which is only 200 miles old).
- Has thanked: 9690 times
- Been thanked: 9957 times
Re: Mushroom Plugs
I've carried one of these for a good while,good enough to get you out of a hole. (ha)
https://www.amazon.co.uk/Stop-Go-1000-P ... th=1&psc=1
After not having a puncture for years,I had two on a new bike,one at only 260 miles. I had the tyre repaired twice with no qualms.
- Trinity765
- Has thanked: 2424 times
- Been thanked: 2380 times
Re: Mushroom Plugs
The Stop & Go kit has got me out of trouble a couple of times though I have always got a proper job done after. Just as well as according to FortNine they're shit.
- Ditchfinder
Re: Mushroom Plugs
I shall insist on an internal patch after watching that vid !
- Has thanked: 1728 times
- Been thanked: 2047 times
Re: Mushroom Plugs
In the real world, what scenario would push the plugs back into the tyre with that force.
- Has thanked: 10094 times
- Been thanked: 6793 times
- GuzziPaul
- Has thanked: 59 times
- Been thanked: 195 times
Re: Mushroom Plugs
I had a puncture on the ferry in a brand new rear tyre, ridden from home to the port 80 ish miles. Fortunately a mate had a DIY mushroom kit and air cannisters with him which was enough to get to a French motorcyle tyre spot. I got a new tyre fitted. We were at the start of a 2000+ holiday including fast motorways and the length of the Pyrenees backwards and forward over the passes. I didn't want the thought of my roadside repair on my mind.
However last week I got a screw in a fairly new car tyre I had that done professionaly with in plug from the inside and thats been fine so far (about 200 miles).
- Ditchfinder
Re: Mushroom Plugs
The guy did a tyre off big mushroom patch, glue on the patch and the stem. After 3 commutes to work I'm not dead yet
