Pool upgrade
Has thanked: 1507 times
Been thanked: 1412 times
Pool upgrade
It's all kicking off today. They drained it on Friday & today the first bloke showed up.
He's positioned 5gal buckets of water all around the pool
Dog checking things out..
I'm guessing this part is gonna get a lot dustier...
Re: Pool upgrade
Discovered why there are buckets of water all over... Thought they'd be out there with jackhammers/Kango's etc removing the old finish. Turns out they'd basting it off. There's some poor fucker under there & it sounds like a B1 taking off with the augmenters lit.
Re: Pool upgrade
Has thanked: 1346 times
Been thanked: 1722 times
Re: Pool upgrade
So what do they use to seal it up again?
Re: Pool upgrade
demographic wrote: Tue Jun 01, 2021 7:48 pm So what do they use to seal it up again?
It's getting a pebble tech stuff instead of the usual plaster. I think it's something like the 3rd one from the top of the 2nd column, Edit: The gunite is intact, they're only removing the plaster so it's still waterproof during the process.
Re: Pool upgrade
Ahh, got you.
I've never worked on a pool so have no idea how the varius layers go and swimming in the local 33 metre pool doesn't count.
Re: Pool upgrade
demographic wrote: Tue Jun 01, 2021 8:50 pm Ahh, got you.
There appears to be three layers. The gunite, then the white plaster, then the blue plaster. Apparently they can reuse the plaster they blasted off instead of throwing it in the landfill... altho I'm not sure about that, but they did pour it into the hopper on the back of the rig.
Re: Pool upgrade
Had a close look at the white stuff they partially blasted off, it's all sparkly & looks to have a very high quartz content. Guy is out there now with a regular pressure washer.
Re: Pool upgrade
All done for today (before 3pm)
Sparkly...
Re: Pool upgrade
Turns out the reason for the sparkly plaster is that it's marble dust, not quartz as I thought.
Tile guys showed up at 9.40, they'd already done one pool before they got here (started at 6am). We have an American today so communication isn't Basil/Manuel like yesterday.
Re: Pool upgrade
Hour & 20 minutes of placing tile:
Re: Pool upgrade
Done & dusted in under three hours:
Yeah, it's frigging bright outside & 100deg...
Has thanked: 1874 times
Been thanked: 2170 times
Re: Pool upgrade
I miss having a pool on days like this... grew up swimming in pools and the ocean.
Has thanked: 836 times
Been thanked: 1238 times
Re: Pool upgrade
I've almost finished getting my pool ready for summer, tried a few plumbing solutions to replace the proprietary rubbish it came with. Now the pool has been shocked and flocced ready for vac to drain this evening. After the plumbing mods the heating seems to work a bit better and it's now a toasty 28 degrees. Not that it matters much as by the time I finish getting it ready I'll want to go to bed.
I'm sure I'll appreciate it in a few days but right now I hate the sight of it.
Has thanked: 10263 times
Been thanked: 6885 times
Re: Pool upgrade
Mine's 28c
Re: Pool upgrade
Managed to get the pool light out of the wall last evening after drilling out the ONE screw. Couldn't separate the parts last night, but got at the clamps with the *correct* pliers this morning. The rubber seal is mullared (cheap part) & I need one screw (cheap). Got all the mineral deposits off the glass with scotchbrite & vinegar.
Plan now is to put one of these spiffy LED bulbs (about $90) in it, comes with a remote to change the colors etc:
Re: Pool upgrade
Yorick wrote: Thu Jun 03, 2021 5:45 pmMine's 28c
Brrrr.....
Re: Pool upgrade
ZRX61 wrote: Thu Jun 03, 2021 5:51 pm
Brrrr.....
Mine's full of water.
Re: Pool upgrade
No crew today, apparently they don't work on Thursdays...
Has thanked: 2550 times
Been thanked: 2285 times
Re: Pool upgrade
Brrrr.....
Mine (aka the North Atlantic ocean) is reported as being around 13 C. I will wait until later in the summer.
