Norton commando 1970 add Electric start or not?
- Has thanked: 9690 times
- Been thanked: 9704 times
Re: Norton commando 1970 add Electric start or not?
I think it depends whether the bike is to be a useable classic or a 100% original bike. They are possibly two different markets,so the purist will be horrified at the merest nut/bolt wrongly attached,while someone who wants to ride the bike will be less bothered.
A modded classic will hurt value for a collector,but may swing the deal for a rider.
- rodbargee
- Has thanked: 352 times
- Been thanked: 969 times
well at the moment I can still swing a leg without dislocating the HIp LIKE MOST VINCENT OWNERS So will leave well alone for the time being I think (they are somewhat dearSkub wrote: ↑Thu May 27, 2021 8:41 pm I think it depends whether the bike is to be a useable classic or a 100% original bike. They are possibly two different markets,so the purist will be horrified at the merest nut/bolt wrongly attached,while someone who wants to ride the bike will be less bothered.
- Has thanked: 264 times
- Been thanked: 1242 times
If it’s on an otherwise mainly original bike, it will affect the price badly, because the bike will then be a special.
- Has thanked: 1326 times
- Been thanked: 1652 times
Will the lecky start give yuu a few more years enjoyment of the bike?
How much is that worth to you?
Oh and what parts do you need to modify to get a lecky start?
Could you get replacement parts so its reversible?
- Has thanked: 15613 times
- Been thanked: 9850 times
Yes, in a heartbeat. Is it reversible if it devalues it and that's a concern?
- Potter
- Has thanked: 2216 times
- Been thanked: 4613 times
If it's anywhere near original then it will devalue it and I wouldn't.
I'd sell and buy something modern, which is what some of my friends have done now they're too old to kick start a big single.
- Has thanked: 7727 times
- Been thanked: 2401 times
Is it a modern conversion? Iirc the originals weren't much better then just using the kickstart.
IIRC the main trick was to have a long, committed kick that had a complete "follow through".
Thats more like it.
If the kit can just be swapped back to standard without knackering the original casings then the only problems are cost and how well it works.
Only the owner really knows how much they are prepared to pay to keep a bike they have that feeling for
Norton’s own Commando electric start did not work well, as you say, but they could be fixed and I expect that most Nortons still in use 46 years later will have had improvements made to the starter system.Rockburner wrote: ↑Fri May 28, 2021 11:24 pm Is it a modern conversion? Iirc the originals weren't much better then just using the kickstart.
The Colorado Norton works and Altons have a good rep. Are you a NOC member? Lots of people with experience there. As said, if it's nut & bolt original I wouldn't do it - if it's for riding yes.
And those people suggesting buying something modern clearly haven't had the good fortune to ride a good Commando. My wife (who is otherwise pillion-phobic) reckoned mine was like floating on air. Sadly they're too heavy and tall for me these days.
