Suzuki GSXR 1216 Mr Turbo 1986 slabside custom show street track drag bike
- Has thanked: 5504 times
- Been thanked: 12763 times
https://www.ebay.co.uk/itm/203461226161 ... SwU4lfSQxG
SUZUKI GSXR 1216 TURBO
Currently running 14psi for road use that dyno at 215bhp can run a lot more if required.
Just serviced new oil and filter, new plugs, rebuilt turbo, carb stripped and cleaned.
1986 Slabside frame heavily modified and strengthened
Extended swing arm
1216 Bandit motor
MTC low compression pistons
Titanium valves and guilds
Up rated head gasket
APE studs
Goodridge hoses oil feeds and brakes
MTC lockup clutch
Billet clutch basket
Dyna 2000 ignition
Dyna volt coils
New Taylor leads
Mr Turbo kit
Rajay 300 Series turbo ( just had a full rebuild by Universal turbos in Fordingbridge £730) 10 miles since.
Mikuni 42mm carb with bell mouth
Wrekin Boost gauge
GPS speedo
Alpha Fuel air mix indicator
GSXR k7 forks just had new ktec seals and oil
GSXR 2016 wheels
zx10 brake callipers
WP rear shock service the end of last year
Air shifter
Lots of titanium nut n bolts
Seat has just retrimmed
Extended swing arm
1216 Bandit motor
APE studs
MTC lockup clutch
Dyna 2000 ignition
Dyna volt coils
New Taylor leads
Mr Turbo kit
Wrekin Boost gauge
GPS speedo
GSXR 2016 wheels
Air shifter
- Has thanked: 532 times
- Been thanked: 7241 times
Re: Suzuki GSXR 1216 Mr Turbo 1986 slabside custom show street track drag bike
They've cut a scary amount of frame away to get the turbo and carb in!
- Has thanked: 2632 times
- Been thanked: 1498 times
That'll be a stress point for sure.KungFooBob wrote: ↑Sat May 22, 2021 8:32 am They've cut a scary amount of frame away to get the turbo and carb in!
- Has thanked: 1326 times
- Been thanked: 1652 times
Naaah, yer alright.
That frame cutout worries me and to my eyes Slabbies are the hunchbacked inbred of the Suzuki lineup.
No doubt they shook the bike industry up in 85 when they came out but I have hidden shallows and just can't see past the looks.
Massive long swingarm and a frame that someone has attacked with a plumbers holesaw aren't helping it for me.
Its tidy enough but just doesn't tick any of my boxes.
- Has thanked: 626 times
- Been thanked: 4072 times
The frame cut is scary, I do like early GSXRs though
- Has thanked: 1054 times
- Been thanked: 354 times
I was gonna to,say I liked it.I then blew up the first pic and saw the non standard curve in the frame .
Was whoever cut and "welded" the frame partially sighted?asmethurst99 wrote: ↑Sat May 22, 2021 5:31 pm I was gonna to,say I liked it.I then blew up the first pic and saw the non standard curve in the frame .
- Has thanked: 2611 times
- Been thanked: 6015 times
Other people's thought processes baffle me sometimes
"I'm adding bits to make this engine more powerful, but I can't fit them in the bike. I know: I'll cut a big chunk of the main structure out!"
Mr. Dazzle wrote: ↑Sun May 23, 2021 7:41 pm Other people's thought processes baffle me sometimes
Then weld it up without a long enough postpurge on the sheilding gas so theres masses of porosity at the weld stop.
Or at least I think that was the direction of travel.
Could also have been they didn't purge the aluminium tubes, still porosity though.
To be fair to em, with a cutout like that, the substandard welding isnt really the biggest issue.
- Has thanked: 1014 times
- Been thanked: 824 times
It doesn't look that well done to me:
The ad says it's been strengthened but all the same ....
Scary!!!
Solve the engineering problem of carb location, nah fuck it - we'll just cut a chunk out of the frame.
200mph on that = big balls or a level of stupidity, I suspect the latter.
I'm out.
I'm out.
