Abba Stand
- Has thanked: 1036 times
- Been thanked: 361 times
Abba Stand
Briefly - If i buy an Abba stand I need to buy appropriate bobbins for it ?(the bike that is )
- Has thanked: 532 times
- Been thanked: 7408 times
- Has thanked: 5408 times
- Been thanked: 12939 times
Re: Abba Stand
mostly yes.... some you can wangle with spacers, sockets etc.
What bike is it for, i think i've got 8-10 abba kits. The fitting kits are about £20.
- Has thanked: 2352 times
- Been thanked: 3507 times
Re: Abba Stand
The fitting kits for the Abba stand also work with the Abba Skylift (unsurprisingly...)
Re: Abba Stand
115 quid inc the adaptors - all good - my cheapo motrax one bent when I took the bike off and was a bit of a drama going on -
- Has thanked: 10094 times
- Been thanked: 6793 times
- GuzziPaul
- Has thanked: 59 times
- Been thanked: 195 times
Re: Abba Stand
Get the front end lift at the same time and they might do a deal (direct from Abba). I've also the base plinth for uneven ground to enable me to use the Abba stand on my hydraulic bench. The stand feet are wider then the bench top and the plinth allows the feet to rest on something solid.
Yup £131 for front and rear lift.
