E10
- MrLongbeard
- Has thanked: 579 times
- Been thanked: 2289 times
E10
Coming to a forecourt near you in September
If Asda don't offer a premium E5 blend I'm going to have to change petrol stations , still it might be a good time to take out shares in seafoam
- Has thanked: 2915 times
- Been thanked: 1846 times
Re: E10
Well mines not on the list of compatible Kwackers.
- Has thanked: 626 times
- Been thanked: 4070 times
- DefTrap
- Has thanked: 2269 times
- Been thanked: 2088 times
- Has thanked: 4246 times
- Been thanked: 2757 times
Re: E10
There was an article in MCN I think saying whilst you don't want to leave it in your tanks for most modern bikes it's fine in regular use. But don't leave it in the tank. They cited lots of European countries already using E10 with few issues and Merca has up to E15 I think.
For me I only ever put Super in the 690 as it has a plastic tank and it only sips petrol so will carry on doing that. I think Esso are still planning on keeping their super E free, so whilst it's marked E5 it's actually 0 except in a few parts of the country.
- Has thanked: 2611 times
- Been thanked: 6015 times
Re: E10
Indycar has been using E98 for donkeys years....the 2% petrol is just to make it burn yellow rather than invisible. So clearly you can make it work in high performance engines.
- Been thanked: 2501 times
Re: E10
Mr. Dazzle wrote: ↑Wed Apr 21, 2021 9:24 am Indycar has been using E98 for donkeys years....the 2% petrol is just to make it burn yellow rather than invisible. So clearly you can make it work in high performance engines.
Has that ever been in doubt? The problems arise when you try to use use it in engines and systems that weren't designed for it.
I've got into the habit of dropping the fuel in the bike's carbs after every run. Possibly not ideal but it seems to work for me.
- Tricky
- Has thanked: 2537 times
- Been thanked: 2543 times
Re: E10
I don't think that point is in question- the main issue ( for me, anyway) with ethanol is its ability to absorb water and the issues that causes over time- I only use Esso super in my old / carburetor equiped bikes now, as unbunging gungy carbs and having older plastic tanks grow and split gets tediousMr. Dazzle wrote: ↑Wed Apr 21, 2021 9:24 am Indycar has been using E98 for donkeys years....the 2% petrol is just to make it burn yellow rather than invisible. So clearly you can make it work in high performance engines.
Re: E10
Sign of the times unfortunately. Modern vehicles are built for it. Older ones can get fucked basically
Have to say, on the auld Triumphs I just turn the fuel taps off slightly before I get home. Need to get the knack of turning it off at just the right point now.
Re: E10
Mr. Dazzle wrote: ↑Wed Apr 21, 2021 10:24 am Sign of the times unfortunately. Modern vehicles are built for it. Older ones can get fucked basically
I do that too, there's no point in wasting fuel.
What would Mad Max do?
- Has thanked: 7727 times
- Been thanked: 2401 times
Re: E10
Roll it?cheb wrote: ↑Wed Apr 21, 2021 11:25 amMr. Dazzle wrote: ↑Wed Apr 21, 2021 10:24 am Sign of the times unfortunately. Modern vehicles are built for it. Older ones can get fucked basically
- DefTrap
Re: E10
Well my late 80s tech Hondas seem to work fine on it.
Of course in 10 years time we might not have petrol at all, and if we do it'll be a grand a litre.
Re: E10
I'm trying to remember the dialogue, that could be a command to start driving, or a comment on the predictable result of his driving.Rockburner wrote: ↑Wed Apr 21, 2021 11:31 amRoll it?cheb wrote: ↑Wed Apr 21, 2021 11:25 amMr. Dazzle wrote: ↑Wed Apr 21, 2021 10:24 am Sign of the times unfortunately. Modern vehicles are built for it. Older ones can get fucked basically
- Has thanked: 2632 times
- Been thanked: 1498 times
Re: E10
I covered this in my live Elevenses webcast ages ago... I had a list of which bikes are E10 ready and it's quite surprising.
I'll dig it out.
[EDIT]It was at the beginning of March -
The link takes you to the relevant section on E10!
It's not the doom and gloom that is being made out.
I'll dig it out.
