loose bottle cage mount on my bike
formula400
Has thanked: 444 times
Been thanked: 863 times
Post by formula400 »
right bear with me on this as I have no idea what its called.
my canyon can have 2 bottles on the frame 1 on the angled front tube and the 2nd on rear.
never used the rear always use the front, and now the mount holes are loose bottom one spins top feels like it about to let go, the top one tightens and the bottom one only tighten a little and just spins (the thing the yellow arrow is pointing to is what I mean) its like they are placed in the frame. the rear ones are still stuck solid to the frame
sorry if that does not make much sense.
I've got on to Canyons Warranty service to see what they say
any way to fix this, what would cause (me falling off) I can't see how that would, surely.
ImageUntitled by lewis wilson, on Flickr
if you click the picture below it will take you to a video
CBR650r :mrgreen:
Has thanked: 2248 times
Been thanked: 1242 times
Re: loose bottle cage mount on my bike
Drill them out and insert new rivnuts of the correct size, providing either you or someone you know has the setting tool.
Has thanked: 5451 times
Been thanked: 13087 times
v8-powered wrote: Fri Apr 16, 2021 12:22 pm Drill them out and insert new rivnuts of the correct size, providing either you or someone you know has the setting tool.
Is the correct answer... many people just glue them. Which also works well enough,
Has thanked: 836 times
Been thanked: 1239 times
I'd go for the lazy option and use glue, if it doesn't hold then try something else.
formula400
Glue seems first go, what glue?
CBR650r :mrgreen:
Depends what I have to hand. I might use a hot glue gun and squirt as much as possible into the hole, or maybe silicone as you can get plenty in there before it sets. If the gap is really small it may need to be something thin like superglue.
Others may have a better idea for metal.
I'd also use a split ring so I don't need to do it up really tight to stop it vibrating loose.
formula400 wrote: Fri Apr 16, 2021 1:26 pm Glue seems first go, what glue?
Something that smells nice
formula400
Le_Fromage_Grande wrote: Fri Apr 16, 2021 3:03 pm
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
CBR650r :mrgreen:
Has thanked: 143 times
Been thanked: 497 times
Post by Silly Car »
As long as you aren’t as hamfisted as docca:
https://www.velonews.com/gear/ask-a-mec ... e-rivnuts/
If you are hamfisted, araldite it.
formula400
Silly Car wrote: Fri Apr 16, 2021 4:01 pm As long as you aren’t as hamfisted as docca:
Unfortunately that's not worked, I've put a small washer between the cage and the boss nut (that's what that greeza called it) seems to be stable. ill ride and see and if not ill order some of that glue
CBR650r :mrgreen:
