Tickover sometimes high
Asian Boss
Has thanked: 498 times
Been thanked: 650 times
Post by Asian Boss »
On my old XL200.
Sometimes it's fine and sometimes it sits at about 4000rpm. From memory this could be the throttle cable sticking or air getting in (between the carb and the engine I think?).
I can't remember what you do to investigate / fix either, it's been so long since I've done anything like this. Any ideas? Or other things which might cause this?
Nidge
Has thanked: 705 times
Been thanked: 701 times
Re: Tickover sometimes high
Post by Nidge »
Firstly spray some some wd40 or anything flammable around the carb rubbers when it's running. If it has an effect on the running you know you've got a cracked carb rubber, although I have to say if it's occasionally sitting at 4k I suspect its a cable or slide issue. How much freeplay have you got on the cable?
I'd go for an air leak between the carb and the head
Been thanked: 7526 times
For £500 plus expenses I can come over and set it on fire for you.
Asian Boss
Thanks chaps (not you KFB, you terrible cunt! ;) ).
I checked the throttle cable and it has what feels like the right amount of free play. It is a bit sticky though so maybe that's the problem. I will try and lubricate it.
I hope it's that, not a leaking carb rubber, I bet it's not easy to get a new one. I wonder if there's some way to rejuvenate or seal cracked old ones. Can't you boil them up in some water with a ha'peth of newt gizard or something?
Nidge
Post by Nidge »
Asian Boss wrote: Thu Apr 15, 2021 3:04 pm Thanks chaps (not you KFB, you terrible cunt! ;) ).
Oh yeah there are loads of different obscure methods to rejuvenate them. None of them work.
Try spraying WD40 on the inlet rubber while the engine is running, if the tick over changes, you've got an air leak.
You can try rubbing 3 in 1 oil into the rubber to rejuvenate it, but I'd be surprised if you can't get one.
Nidge wrote: Thu Apr 15, 2021 3:06 pm
Spoil sport, I was going to move onto Wintergreen oil after the 3 in 1.
Nidge
Post by Nidge »
Been thanked: 2616 times
Oil of wintergreen is the usual suggestion for rejuvenating rubber, AKA surgical spirit.
Be careful applying it if there is 3 in 1 on the rubber, it reacts and forms an explosive gas.
Asian Boss
I took the throttle apart, it seems to be moving fine. I got some Silkopen down the cable anyway.
The carb to hear rubber has electrical tape round it so I'm guessing that's the culprit. I think I'll order one. The bike isn't running as the battery's dead.
