AS NEW: REVIVING A DUCATI MIKE HAILWOOD REPLICA
- Has thanked: 5504 times
- Been thanked: 12762 times
- Scotsrich
- Has thanked: 71 times
- Been thanked: 537 times
Re: AS NEW: REVIVING A DUCATI MIKE HAILWOOD REPLICA
Lovely bike and a ton of work obviously went into it but why why why did they powder coat the frame instead of painting it.
- Has thanked: 5945 times
- Been thanked: 4933 times
Is it more resilient to knocks during reassembly?
- Has thanked: 7727 times
- Been thanked: 2401 times
Now that's a fantasy garage piece
That's lovely, one of my favourite bikes ever.
demo, sorry about the pod filters but the original didn't have an airbox anyway. My 900SS had bellmouths with a bit of wire mesh over the end.
- Has thanked: 1326 times
- Been thanked: 1652 times
For me, personally powdercoating a frame isn't always the best.
For a start it makes it a right pain in the arse if you later decide you want to move a bracket and just want to clean a bit of paint off, weld it on then painting that bit.
Inspecting a ferromagnetic frame for cracks can be done with magnetic particle testing through a bit of paint but as it gets thicker its not as effective and powdercoating is a usually a lot thicker.
Admittedly I don't think thats common on bike frames but it's possible.
Also powder coating can rust underneath it when it cracks or uncoated areas like where the engines mount, stone chips can be a place where salty water gets a real foothold and causes the powdercoating to come off in fair sized flakes. Check out 4wd bullbars and towhitches for that one.
Paint can but its simpler to repair.
Then theres the time spent sending it away where you can't work on the project, everyone has a local paint shop but not as many have a powdercoating shop just round the corner.
I think powdercoating has its place but I feel theres a good reason a lot of bike manufacturers still paint frames.
Hell, I never even noticed the pods but as you say a few bike never even came with filters in the first place.
What gets on my tits is when the builder launches the mudguards, the airbox the and the filter in the skip and theres a straight line of sight from the rear tyre and the inlet side of the carb for water/crap/dust to shoot into the engine.
Even more so on modern bikes where a rebore involves re-nicasil coating the bores instead of ambling into the local precision engineering shop with a new oversize piston, the cylinder and some cash.
- Has thanked: 2611 times
- Been thanked: 6015 times
On the plus side however, when you're not sure if the bike is running lean on one side you can reach down and covet the bellmouth a bit with your hand.demographic wrote: ↑Sat Apr 10, 2021 10:17 am What gets on my tits is when the builder launches the mudguards, the airbox the and the filter in the skip and theres a straight line of sight from the rear tyre and the inlet side of the carb for water/crap/dust to shoot into the engine.
The 11th commandment "thou shalt not covet thy neighbours belmouth"
Another way is to pull the choke to richen the mixture.
- Has thanked: 626 times
- Been thanked: 4070 times
It looks nice
I'm not a fan of powder coated frames, it's too thick and scratches too easily, but it's a hell of a lot cheaper than getting a frame sprayed properly.
- Pirahna
- Has thanked: 1773 times
- Been thanked: 1109 times
A friend has one, and a mint black 70's 900SS, and MK1 Le Mans.
We often gravitate towards something we lusted after at an impressionable age so this Ducati is one I like.
There's no choke on those Dell'ortos. You had to tickle the carbs until they flooded then jump on the kickstart and hope.demographic wrote: ↑Sat Apr 10, 2021 6:11 pmThe 11th commandment "thou shalt not covet thy neighbours belmouth"
Ahh, fair enough.
The only time I remember anyone having to tickle a carb was my much older brothers Triumphs and I have no idea what carbs they had.
One brother must have pushed his Triumph further than he rode it and another brothers Triumph took him to Nordcap and back with no issues.
- Has thanked: 746 times
- Been thanked: 701 times
The Amals on the Bonneville do have chokes, but like a lot of people my FiL removed them.demographic wrote: ↑Sat Apr 10, 2021 7:21 pmAhh, fair enough.
Strictly speaking they have an air slide rather than a choke- but yes removing them and plugging the hole where the cable enters is pretty common practiceMr. Dazzle wrote: ↑Sun Apr 11, 2021 7:04 amThe Amals on the Bonneville do have chokes, but like a lot of people my FiL removed them.demographic wrote: ↑Sat Apr 10, 2021 7:21 pmAhh, fair enough.
- GuzziPaul
- Has thanked: 59 times
- Been thanked: 195 times
Thats a high value garage there. I've always thought of a MH replica to be a 900SS in a different froc and slightly more affodable. I've put pod filters onto my Le Mans asthe wire mesh on the original bellmouths are only good for stopping small children and birds been sucked in.
I do like this MH rebuild, although do think it's more for looking at rather than riding.
