90° Tyre valve.
Has thanked: 1746 times
Been thanked: 2085 times
90° Tyre valve.
What you got ???
Checking pressure's on the tracer is a pita. Particularly front. On next tyre change gonna fit 90° jobbies.
SBS got these, any good ???
https://www.sportsbikeshop.co.uk/motorc ... prod/48132
Has thanked: 5450 times
Been thanked: 13085 times
Re: 90° Tyre valve.
They look a bit cheap and nasty in terms of metal... I'd be spending more and buying nice ones.
If wanting the simple option, there's these extenders.
https://www.ebay.co.uk/itm/2-Pcs-90-Deg ... %3A2334524
Re: 90° Tyre valve.
I've got some of those but by the time I've unscrewed them off, I've lost pressure. Don't fancy leaving them on.
chutzpah
Has thanked: 21 times
Been thanked: 96 times
Re: 90° Tyre valve.
Post by chutzpah »
I used a right angle connector for my Kawasaki as access was a nightmare, but not valves - just a connector I could leave connected to my pump.
BMW they're in the wheel spoke and it's bliss
GuzziPaul
Has thanked: 59 times
Been thanked: 195 times
Re: 90° Tyre valve.
Post by GuzziPaul »
I got given one by the tyre fitter when I had a tyre changed on the Tuono. Fitted it once and much like Dodgy I've not kept it on as I reckon the wheel would need rebalancing. A different adapter on the pump might be a better option. Certainlt the straight metal ones at garages won't fit due to front disks but the ones with a lever that lock it in place or the screw on ones on a portable electric pump are fine.
I got this as part of a Classic Bike subscription.
Recommendand will even recover a fully flat car tyre that a neighbour had tried to inflate with another pump he had.
Re: 90° Tyre valve.
I can pump ok, its the pressure gauge access that's the problem.
Druid
Has thanked: 276 times
Been thanked: 896 times
Re: 90° Tyre valve.
Post by Druid »
I know someone who had some of those right angle adaptors on a Ducati Multi. He left them on all the time and the out of balance forces eventually caused the tyre valve to split and the tyre to deflate. He was in the west of Scotland at the time and it took 6 hours for the RAC to recover him to a garage and get a new valve fitted.
I had some proper right angled valves on my MV and had no problems though
G.P
Has thanked: 2029 times
Been thanked: 1310 times
Re: 90° Tyre valve.
Post by G.P »
I've got a flexible line on both of my pumps so straight valves are accessible,but I've got 90 degree valves so happy days.
Can't remember the last time I used a forecourt pump, might have been in France about 6 years ago!
Been thanked: 7526 times
Re: 90° Tyre valve.
The wifes F700GS has a valve stuck out of one of the cast spokes near the rim. I'd never seen anything like it, makes sense tho'
Has thanked: 2550 times
Been thanked: 2285 times
Re: 90° Tyre valve.
I have 2 right-angle extenders somewhere, bought for the Bonnie which was a pig to inflate otherwise. Like others I never trusted leaving them on, and fumbling to get them on or off could lose a few pounds.
Has thanked: 229 times
Been thanked: 575 times
Re: 90° Tyre valve.
Standard on my Sprint 1050s, and also on the KTM.
ogri
Has thanked: 1036 times
Been thanked: 224 times
Re: 90° Tyre valve.
Post by ogri »
Standard on most trumps nowadays i think.
Ignorance is bliss
Has thanked: 261 times
Been thanked: 1265 times
Re: 90° Tyre valve.
G.P wrote: Sun Apr 04, 2021 10:00 am Can't remember the last time I used a forecourt pump, might have been in France about 6 years ago!
I haven’t used one since they started charging money for it.
Re: 90° Tyre valve.
Problem solved. Already had clip on flexi piece, add piece with valve and job done. Obviously it doesn't need to be 90° but that's what I got.
Re: 90° Tyre valve.
They make 90 degree ones like this:
iansoady
Been thanked: 169 times
Re: 90° Tyre valve.
Post by iansoady »
Or like this:
I have one and it's very convenient.
Re: 90° Tyre valve.
iansoady wrote: Mon Apr 05, 2021 12:21 pm Or like this:
That’s clever. It’ll keep the reading while I raise it to my good eye.
