Car polishers?
- Has thanked: 15628 times
- Been thanked: 10069 times
Car polishers?
Are these sort of polishers any good? Not looking to spend a fortune as it'll probably only get used a few times.
https://www.ebay.co.uk/itm/16PCS-5-Car- ... 1196.m2219
https://www.ebay.co.uk/itm/Electric-Car ... Sw4a9gDD0I
- Has thanked: 826 times
- Been thanked: 1231 times
Re: Car polishers?
If you get one make sure it's random orbit, same as sanders to avoid swirls. I bought a cheap one to get rid of a gauge in my van, it did OK but was aggressive so I didn't like using it.
Maybe if I had more practice it would be fine.
- Has thanked: 5408 times
- Been thanked: 12939 times
- Has thanked: 1728 times
- Been thanked: 2047 times
Re: Car polishers?
Be careful where you put it down, if it picks up a bit of grit, oh dear, personally I'd stick with a hand job.
- Has thanked: 1464 times
- Been thanked: 1371 times
Re: Car polishers?
The kits that include the pads usually come with the cheapest pads made & are total crap. I rinsed a pad recently & discovered they used water based glue to attach the velcro...
- ogri
- Has thanked: 1016 times
- Been thanked: 218 times
Re: Car polishers?
$10 and you can give me a hand job!Dodgy knees wrote: โSat Mar 27, 2021 3:22 pm Be careful where you put it down, if it picks up a bit of grit, oh dear, personally I'd stick with a hand job.
Unless you know what you are doing i would stick to traditional cleaning, less chance of damaging the paintwork!
Ignorance is bliss
Re: Car polishers?
You're about the 5th person to say that to me! I'm starting to bottle it a bit now. I suppose I do need the exercise...ogri wrote: โSat Mar 27, 2021 10:12 pm$10 and you can give me a hand job!Dodgy knees wrote: โSat Mar 27, 2021 3:22 pm Be careful where you put it down, if it picks up a bit of grit, oh dear, personally I'd stick with a hand job.
Re: Car polishers?
You've got to be a proper spanner to fuck it up with a das6Taipan wrote: โSun Mar 28, 2021 11:30 amYou're about the 5th person to say that to me! I'm starting to bottle it a bit now. I suppose I do need the exercise...ogri wrote: โSat Mar 27, 2021 10:12 pm$10 and you can give me a hand job!Dodgy knees wrote: โSat Mar 27, 2021 3:22 pm Be careful where you put it down, if it picks up a bit of grit, oh dear, personally I'd stick with a hand job.
Re: Car polishers?
Me earlier!
- gremlin
- Has thanked: 792 times
- Been thanked: 4664 times
Re: Car polishers?
On a similar vein, anyone used one of the kits for bringing headlights back from a slow, yellowing death? Noticed one of the Merc's headlights is looking a bit sorry for itself at the weekend.
https://www.eurocarparts.com/p/holts-he ... MREALw_wcB
Re: Car polishers?
Solvol & a rag.gremlin wrote: โMon Mar 29, 2021 2:40 pm On a similar vein, anyone used one of the kits for bringing headlights back from a slow, yellowing death? Noticed one of the Merc's headlights is looking a bit sorry for itself at the weekend.
- Has thanked: 1036 times
- Been thanked: 361 times
- Has thanked: 532 times
- Been thanked: 7408 times
Re: Car polishers?
I did the lights on my FTO with ever increasing numbered grades of wet and dry (with lots of wet). Then polished off with some cutting compound. They turned out brilliant.gremlin wrote: โMon Mar 29, 2021 2:40 pm On a similar vein, anyone used one of the kits for bringing headlights back from a slow, yellowing death? Noticed one of the Merc's headlights is looking a bit sorry for itself at the weekend.
- gremlin
Re: Car polishers?
Tried that, as well as a glass polishing compound I have. No joy.ZRX61 wrote: โMon Mar 29, 2021 4:36 pmSolvol & a rag.gremlin wrote: โMon Mar 29, 2021 2:40 pm On a similar vein, anyone used one of the kits for bringing headlights back from a slow, yellowing death? Noticed one of the Merc's headlights is looking a bit sorry for itself at the weekend.
I think I need to get in with ever-decreasing coarseness W&D and then use the polishing stuff.
It's gonna get messy.
Re: Car polishers?
Are you sure the yellow is just on the surface and not all the way through?gremlin wrote: โTue Mar 30, 2021 9:13 amTried that, as well as a glass polishing compound I have. No joy.ZRX61 wrote: โMon Mar 29, 2021 4:36 pmSolvol & a rag.gremlin wrote: โMon Mar 29, 2021 2:40 pm On a similar vein, anyone used one of the kits for bringing headlights back from a slow, yellowing death? Noticed one of the Merc's headlights is looking a bit sorry for itself at the weekend.
- gremlin
Re: Car polishers?
You can feel it as you rub your finger over it, so assuming its surface. It's not actually that bad and you struggle to see it at any sort of distance. I only noticed it as I was tidying up the engine bay with the bonnet lifted.
Currently it's only on the top edges of one light, so not too bad, but if I can tackle it now, it's the proverbial stitch in time.
Re: Car polishers?
Well I suppose the logical approach is to try it by hand first and if it doesnโt come out right, then try a polisher.
