oil burner suzukis - anoraks please apply
- Has thanked: 256 times
- Been thanked: 143 times
I happened to be thinking about this earlier, anyone a oil cooled gxsr geek? which bikes were fitted with them? i shall try and list the ones i can remember
750 slabby
1100 slabby
750 slingshot
1100k etc puff daddy shape
teapot 600
teapot 750?
bandit 600
bandit 1200
there must be some other suzukis that had them?
anything oddball such as a bimota?
750 slabby
1100 slabby
750 slingshot
teapot 600
teapot 750?
bandit 600
bandit 1200
- Has thanked: 1326 times
- Been thanked: 1652 times
Re: oil burner suzukis - anoraks please apply
Think the Bimota SB5 had an oil boiler (not burner you spanner) 1100 engine in it as well.
- Has thanked: 10117 times
- Been thanked: 6649 times
I bought a new RF900 in purple. My first brand new bike
- Has thanked: 521 times
- Been thanked: 650 times
The RFs were water cooled.
Shit loads of Suzukis were air / oil cooled.
- Has thanked: 532 times
- Been thanked: 7238 times
- Has thanked: 626 times
- Been thanked: 4070 times
Without going into mega detail there are the following oil cooled Suzuki engines that I can remember
600 used in Bandits and Teapots
Long stroke GSXR750 (there are 4 versions of this)
Short stroke GSXR750
Short stroke GSX750 used in Bandits, Inazumas and Teapots
Slabby 1074
Slingshot 1127 (at least 2 versions)
GSX1100F tourer has a unique engine
GSX1100G shafty
Bandit 1200 used in Bandits, Inazumas and the GS1200SS
GSXR engines have straight cut primary gears and roller cam chains, Bandits have helical primaries and hyvo cam chains.
Bimota SB6 and 7 have water cooled GSXR engines, and you have to take the engine out to change the gearbox sprocket.
Slabby 1074
GSX1100G shafty
Doh!demographic wrote: ↑Tue Mar 23, 2021 5:28 pm Think the Bimota SB5 had an oil boiler (not burner you spanner) 1100 engine in it as well.
Oops, fail on my part.
I should have realised it was 1135 and not 1127cc.
I think that was the GS1200SS.
Isn't any non watercooled bike with an oil cooler fitted essentially oil cooled? GS500E, 750 Katana and GSX1400 for example.
The X meant 4 cylinder.
OR..
The 'GS' portion is a designation for Suzuki street bikes, going back a long ways. the 'X' means dual overhead camshafts, and the 'R' denotes racing.
- Been thanked: 2501 times
I thought the X meant 4 valves per cylinder. GS is 2V per cylinder, GSX is 4V per cylinder across the range AFAIR.
Correct for most of the world, but in the US, GSXs were sold as GSs
Didn't those suzuki engines spray the underside of the piston with oil to cool it, or something specific?Asian Boss wrote: ↑Wed Mar 24, 2021 9:07 amI think that was the GS1200SS.
