gluing a plastic lug thing, what to use
formula400
Has thanked: 444 times
Been thanked: 863 times
Post by formula400 »
So whilst doing some bits I've managed to brake this lug off , what's the best way to glue it/fix it back on that's nice and strong???
cheers
CBR650r :mrgreen:
Has thanked: 7814 times
Been thanked: 2527 times
Re: gluing a plastic lug thing, what to use
Is it plasti-weldable?
formula400
Rockburner wrote: Wed Mar 17, 2021 2:37 pm Is it plasti-weldable?
I don't even know what that means
CBR650r :mrgreen:
formula400
is that it???
CBR650r :mrgreen:
IME once those kind of lugs break, they're broken, the stress of pulling them in and out of the rubber will break any repair
formula400
£57 for a new one seems good value then
CBR650r :mrgreen:
formula400 wrote: Wed Mar 17, 2021 3:35 pm £57 for a new one seems good value then
Yes, very good
Has thanked: 836 times
Been thanked: 1238 times
I wouldn't trust trying to stick that, even with plastic weld. I think I'd bend a bit of metal to go right over and stick to the plastic either side. Then tap a hole (or drill it and use the existing clip) and it should be plenty strong enough.
The problem I see with that is the panel could be a couple of mm proud when I goes back on, some more careful forming of the metal will help with that.
Asian Boss
Has thanked: 498 times
Been thanked: 650 times
Post by Asian Boss »
Plastic welding is melting it back together with a hot thing like a soldering iron. I think you can get it professionally done.
Like LFG I think it's difficult to ever make a good repair. The most successful I ever managed involved drilling and wiring it together in several areas then covering with an epoxy putty. I was always careful with that panel after that and a good yank would have fucked it I suspect. Plastic welding is probably the most durable.
formula400
Right cheers you lot, seems like a lot of sodding around that might not even work.
New one it is.
CBR650r :mrgreen:
Has thanked: 218 times
Been thanked: 689 times
Screwdriver had a weldy thing that heated a wire clip into the plastic for support..I suspect they were a bit spendy.
Has thanked: 2550 times
Been thanked: 6244 times
Thermoplastics, I.e. the sort of heat formed/injection moulded stuff you're looking at here, are notoriously hard to bond to...even with brand new materials going through all sorts of fancy surface treatments they're not great. So you're always gonna struggle with a used bike bit and DIY
iansoady
Has thanked: 59 times
Been thanked: 169 times
Post by iansoady »
I've had success with superglue and - wait for it - baking soda. Stick the parts with superglue. When set, make a leayer of superglue over the area and sprinkle with the baking soda while still liquid. It will set into a hard substance which is surprisingly strong. You can go on to add more layers.
I used this technique for the lugs on a Triumph Tiger side cover and it lasted well.
Ditchfinder
Has thanked: 621 times
Been thanked: 692 times
Post by Ditchfinder »
Fixed a broken lug using a soldering iron and melting zip ties into the areas that needed toughening up. Lasted fine, was as strong as before. Watched a couple of tutorials on YT then practised on a bit of scrap first.
Druid
Has thanked: 276 times
Been thanked: 896 times
Post by Druid »
I've had good results using Plastex
https://www.plastex.net
dayglo jim
Has thanked: 23 times
Been thanked: 19 times
Post by dayglo jim »
If you have a 3D printer I'd make another bracket and weld that to the panel, rather than the snapped part to the bracket. You could widen the base of the bracket to give it a bigger base to weld with.
formula400
Got to love flowers triumph, order Wednesday night, here this morning.
CBR650r :mrgreen:
Definitely the easiest solution :D
formula400
Mr. Dazzle wrote: Fri Mar 19, 2021 4:03 pm Definitely the easiest solution :D
For sure.
CBR650r :mrgreen:
