DOUBLE SHOT: TWO VELOCETTE MOTORS POWER HAZAN’S LATEST
- Has thanked: 5503 times
- Been thanked: 12760 times
https://www.bikeexif.com/velocette-motorcycle-max-hazan
I posted this more for the engineering rather than the slightly dubious aesthetics.
- Has thanked: 2914 times
- Been thanked: 1846 times
Re: DOUBLE SHOT: TWO VELOCETTE MOTORS POWER HAZAN’S LATEST
I like it, crazy engineering, rim brakes at the front, supercharger, MTB air shock on the rear!
- Has thanked: 626 times
- Been thanked: 4070 times
The engineering looks a bit dubious, but I quite like the looks
- Been thanked: 2501 times
I've not seen a double sided toothed belt before. The engines nest pleasingly on the right hand side too.
- Has thanked: 216 times
- Been thanked: 666 times
I would say that is not designed to be run in anger....what happens the first time a stone or grit land on the belt?
Plus the rim brake is a bit pointless....with two 500 velo singles, you are virtually going to stop as soon as you roll the throttle off.
You'd have to get it to run first - the whole things a sculpture
bloody impressive though. I'd have that in the conservatory as a piece of art all day.Le_Fromage_Grande wrote: ↑Wed Mar 17, 2021 3:25 pmYou'd have to get it to run first - the whole things a sculpture
- Has thanked: 2192 times
- Been thanked: 426 times
Have you ever seen such a ridiculous riding position?!
Sadly yes, have you not seen a AP50 with ace bars
I couldn't find a picture of a FS1E with drops
- Has thanked: 1326 times
- Been thanked: 1652 times
My old Fizzie had drops, well technically they were Ace Bars.
I used to put my feet on the back pegs and chin on the speedo and even saw 55 on the clock when in that ridiculous aero position.
- Cousin Jack
- Has thanked: 2560 times
- Been thanked: 2183 times
RHS looks tidy
LHS is an 'elf 'n safety nightmare. I would be tucking my trews into a pair of high boots on the left.
Rim brakes are awful.
Suspension? Words fail me.
As a piece of metal sculpture it's not bad, as a motorcycle it is nil points from me.
Yes...the trip downhill not withstanding...it's for looking at.
Having said that, if it turned up in my living room (I have no conservatory) I would try to start it.
- Has thanked: 9688 times
- Been thanked: 9704 times
I sort of like the visual aspect,but even if it does run,I wouldn't want to ride it.
Makes me want to fit handlebars to my upstairs shitter.
