Bought racking for the garage.
Has thanked: 823 times
Been thanked: 4887 times
I currently have a plethora of London brackets holding up various bits of wood and masquerading as garage shelves. One day it will collapse until I get myshelf together (see what I did there?).
Due to piers, pipes etc in the garage, I'm limited in where i can put racking, but I have a wall I can free up just a smidgen over 2400mm wide. I found these on the web: https://www.bigdug.co.uk/shelving-c4505 ... unit-p1304
No love for the colour or anything, just they come in 1200mm wide units, which fits my gap nicely.
Any opinions one way or the other? Nothing particularly weighty going on the them, just usual garage crap like tins of paint, bottles of whatjacallit, few thingameebobs, etc.
Any other suppliers recommended?
Has thanked: 10406 times
Been thanked: 6948 times
Re: Bought racking for the garage.
I had 4 of them jobbies (or similar) in my garage in Thame. Very good. I fixed them to the wall.
Has thanked: 841 times
Been thanked: 1245 times
I recently had the same thought. After returning some terrible cheap metal shelves I bought some of these, they are shelves and haven't collapsed yet so meh.
https://www.toolstation.com/garland-5-t ... ing/p31174
Not As strong as metal but I'm just putting a few tool boxes on them and these won't rust.
Has thanked: 9991 times
Been thanked: 10304 times
Mrs.Skub bought a load of those for underneath/cellar in our house. I was a production line operative for most of a day. :roll:
They seemed strong and stable enough once the wooden shelf is in place. I reckon they could take more weight than you'd think at first.
Has thanked: 543 times
Been thanked: 7672 times
Mines really sturdy.
There's some weight on that middle shelf with all those fluids.
Has thanked: 152 times
Been thanked: 506 times
Post by Silly Car »
We’ve got something very similar, as has been said, bolt them to the wall as that stiffens them up no end.
Once mine are in the garage rather than dining room / dumping ground / workshop, I’ll bolt the shelf boards to cross braces and bolt / rivet the lot together as a single unit.
DefTrap
Has thanked: 2276 times
Been thanked: 2200 times
Post by DefTrap »
I tested some that 'looked really sturdy' by using them as an impromptu ladder. Not that successful. They really do mean it when they say 50kg limit per shelf.
But it turns out smacking it with a big hammer makes it nearly serviceable again.
Been thanked: 2628 times
I'd be minded to replace the MDF with plywood of a similar thickness, partly because it's stronger but mostly because I dislike MDF.
kendo57
Has thanked: 258 times
Been thanked: 590 times
Post by kendo57 »
I bought mine from Costco , they have gone up since i bought mine but still very good quality.
cheb wrote: Tue Mar 16, 2021 8:14 pm I'd be minded to replace the MDF with plywood of a similar thickness, partly because it's stronger but mostly because I dislike MDF.
It's a temporary arrangement. Has been for the last 12 years.
Zimbo
Has thanked: 88 times
Been thanked: 135 times
Post by Zimbo »
I've used quite a few of them at work and in my garage, they're good for the money, easy to assemble and take more weight than you expect. Screw them to the wall for top rigidity, or if fitting a couple side by side bolt them together.
If anybody needs the 900mm wide version (900 x 450 x 1800mm high) Screwfix do an almost identical version for not much money
https://www.screwfix.com/p/5-tier-steel ... 00mm/2817r
Asian Boss
Has thanked: 498 times
Been thanked: 650 times
Post by Asian Boss »
I've got some similar.
I remember when I was thinking about them Big Pete was fairly disparaging.
I don't think they'd hold a fraction of the weight they claim and even partially loaded if you catch an upright it could bring the whole lot tumbling down.
That said I have three or four sets and they're ok. And cheap, which was why I got them.
The PAWG is moving into her new house soon and I'll probably get her some for her garage.
Asian Boss wrote: Wed Mar 17, 2021 3:42 pm I've got some similar.
Plentio fixio to wallio :)
Scotsrich
Has thanked: 72 times
Been thanked: 554 times
Post by Scotsrich »
When I was looking for shelving for a cupboard in my flat to put stock for my website on I went to a local shop fitters who had a massive warehouse filled with bits and pieces.
I got second hand shelves that you could have sat a car on for not much money. And as a bonus when I moved they were easily sold.
Maybe you’ve got something like that near you.
Has thanked: 1541 times
Been thanked: 1442 times
I have Whalen brand.
Mine are the older version with 1/2in thick shelves, now it's somewhat thinner. Strong enough to support a C6 transmission.
