Drilling damper rods?
Has thanked: 15949 times
Been thanked: 10243 times
Thinking about fitting fork valves in my NC700X, which means i'll need to drill the damper rods, but I no longer have access to a workshop and a bench drill etc. Anyone ever drilled damper rods? Am I going to have any success with them in a vice and using my Makita 18v drill?
Has thanked: 9822 times
Been thanked: 10144 times
Re: Drilling damper rods?
I'd want to know exactly what I was doing there TP.
Been thanked: 7526 times
Can't be any scarier than drilling carb slides, just do it!
Has thanked: 2402 times
Been thanked: 3625 times
Taipan wrote: Sun Mar 07, 2021 8:06 pm Thinking about fitting fork valves in my NC700X, which means i'll need to drill the damper rods, but I no longer have access to a workshop and a bench drill etc. Anyone ever drilled damper rods? Am I going to have any success with them in a vice and using my Makita 18v drill?
I had to drill the damper rods on my 350LC when I fitted YSS cartridge emulator valves to the forks. But I did have a pillar drill and a countersink bit. I think it would be possible using a hand held drill as long as the damper rod was held steady in a vice.
Go for it! What could possibly go wrong? :mrgreen:
Has thanked: 836 times
Been thanked: 1238 times
Something like this may help.
Is it new holes or opening up existing holes to a larger diameter?
If it's opening up then I wouldn't be worrying about having the right kit.
On my damper rod conversion, the instructions said to open up existing holes and drill additional ones. But if you use a centre punch to locate the drill bit and use a small diameter one to drill a pilot hole before going large, you should be OK.
Mussels wrote: Sun Mar 07, 2021 10:05 pm Something like this may help.
Less than £30 too. I'll get one of those I think. Cheers for posting that. :thumbup:
https://www.machinemart.co.uk/p/clarke- ... with-vice/
iansoady
Has thanked: 59 times
Been thanked: 169 times
Post by iansoady »
Use one of these to start it:
https://www.cromwell.co.uk/shop/cutting ... rills/f/68
Less chance of it wandering.
