New Brake lever/blade replacement
formula400
Has thanked: 444 times
Been thanked: 863 times
Post by formula400 »
Right again resulting from my off id like to change the brake lever as the end is damaged and scuffed, does not need replacing but looks ugly.
ive got Shimano MT201 / UR300 on there. any idea where to source just the lever its self??? and that way won't have to replace too much and bleed them.
CBR650r :mrgreen:
formula400
Re: New Brake lever/blade replacement
madness, just spoke to a shop, you can't just buy/replace the lever, you need the whole until replacing (cheap at £14) but then need the bugger bled.
https://www.tredz.co.uk/.Shimano-BL-MT2 ... lgQAvD_BwE
CBR650r :mrgreen:
Has thanked: 5451 times
Been thanked: 13087 times
If it doesn't come with one you'll need an Olive and Barb too.. Bleeding ain't hard, but you'll need Shimano fluid and a bleed method.
formula400
CBR650r :mrgreen:
formula400 wrote: Thu Mar 04, 2021 11:30 am as in this way
https://www.bikeradar.com/advice/worksh ... sc-brakes/
excessive, IMO you'll just need the bleed cup and a bit of patience.
formula400
oh ok, that did not seem too intense, ill get the bits ordered. what's the olive and barb??
CBR650r :mrgreen:
formula400
will that need just a normal std bleed kit???
CBR650r :mrgreen:
formula400 wrote: Thu Mar 04, 2021 12:19 pm will that need just a normal std bleed kit???
I've always done Shimanos just with the bleed cup. Well, in the last 10 years, before that it was syringe.
formula400
weeksy wrote: Thu Mar 04, 2021 12:20 pm
what is that???
CBR650r :mrgreen:
Has thanked: 1829 times
Been thanked: 1469 times
Scuffed levers ...
Just shows you are trying hard enough ...
Who cares :-)
