Weird motorcycle things you remember
Prompted by Weeksy's heated grip trauma, I remember an article in a motorcycle magazine in the 80s where someone decided to heat their handlebars by rerouting the water cooling hosing so that the hot water flowed in one end of the handlebars and out the other, I tried to find pictures of this wondrous piece of engineering but sadly, I couldn't find any.
What other weird and wonderful things do you remember?
Has thanked: 5453 times
Been thanked: 13102 times
Re: Weird motorcycle things you remember
I'm impressed anyone is still opening my thread.
Been thanked: 7539 times
That helmet attachment that worked like a windscreen wiper.
The Norton Nemesis.
Carlos Checa having a BT1100 as his road bike.
Been thanked: 2618 times
Jock Kerr's solution in making 250cc bikes legal for learners, who could only ride up to 125cc bikes.
Tilting sidecars for similar reasons.
The French dogturd cleanerupper, based on an XT500.
Paired brake discs. Two discs running next to each but with one caliper and three pads.
Inboard disc brakes by Honda.
Spinning disc visors for better visibility in the rain.
weeksy wrote: Fri Feb 12, 2021 3:08 pm I'm impressed anyone is still opening my thread.
It's Friday afternoon, I'm clock watching, waiting to go home
Has thanked: 261 times
Been thanked: 1266 times
Reliant adverts in Motorcycle Mechanics.
Has thanked: 7821 times
Been thanked: 2531 times
Le_Fromage_Grande wrote: Fri Feb 12, 2021 3:07 pm Prompted by Weeksy's heated grip trauma, I remember an article in a motorcycle magazine in the 80s where someone decided to heat their handlebars by rerouting the water cooling hosing so that the hot water flowed in one end of the handlebars and out the other, I tried to find pictures of this wondrous piece of engineering but sadly, I couldn't find any.
Sounds like Malcom's Patent Winter 'Keep-U-Warm' Exhaust Extension - that wound around the rider's body before feeding back into the carb.....
Bigjawa
Has thanked: 221 times
Been thanked: 878 times
Post by Bigjawa »
Bar snake, was like a solid rubber hose that you fed through your bars to kill vibration, you got a liquid version too that poured in and set.
Then there was Slik Move, a bike racing board game.....
Bigjawa wrote: Fri Feb 12, 2021 3:47 pm
Was that the one with Grand Scratch as the track?
Has thanked: 2636 times
Been thanked: 1523 times
I knew the guy. Complete lunatic. His kit was for the courier favourite - the CX500.
1913
Has thanked: 20 times
Been thanked: 42 times
Post by 1913 »
Hardley Worthit sold a kit that used engine oil to heat the grips.
I absolutely shit you not.
1913
Post by 1913 »
Alister ? early 70's exhaust silencing valve.
Think of a throttle valve with holes in the flap, operated by a lever on the handle bar.
open out of town, closedish in town.
1913
Post by 1913 »
Police on bike that were far slower than bike with a quarter of the capacity.
Newey
Has thanked: 41 times
Been thanked: 48 times
Post by Newey »
Weird that the RD200 came with electric start but none of its brothers did. Also the RD125 came with a sort of steering damper ie a knob that you turned on the head stock to tighten the stem bearings.
Has thanked: 218 times
Been thanked: 689 times
1913 wrote: Fri Feb 12, 2021 11:22 pm Police on bike that were far slower than bike with a quarter of the capacity.
I have a couple of those.
Druid
Has thanked: 276 times
Been thanked: 900 times
Post by Druid »
Newey wrote: Sat Feb 13, 2021 1:22 am Weird that the RD200 came with electric start but none of its brothers did. Also the RD125 came with a sort of steering damper ie a knob that you turned on the head stock to tighten the stem bearings.
iirc the RD200 alternator and starter motor were the same component - feed power to it to start the engine, then let the engine turn it to generate electricity.
The YDS7 and YR5 also used a friction steering damper, as did my Suzuki T500
Has thanked: 2552 times
Been thanked: 6260 times
Integrated Starter Generator. Only now becoming common (on cars) again.
Druid wrote: Sat Feb 13, 2021 10:16 am iirc the RD200 alternator and starter motor were the same component - feed power to it to start the engine, then let the engine turn it to generate electricity.
Same as the engine on a Smart car :)
asmethurst99
Has thanked: 1043 times
Been thanked: 362 times
Post by asmethurst99 »
Sidewinder combo for LC's
