Press fit bearings
- Has thanked: 1829 times
- Been thanked: 1469 times
Press fit bearings
I have press fit BB on my HT.
I had to fit some new bearings 3 weeks ago - which was fair does, the original ones had done 3 years. It is a Wheels Manufacturing one, so it comes with an alloy sleeve and replaceable bearings.
Old bearings out, new in , without too much hassle - and I did use a bearing press not a hammer ....
Two muddy rides on the Downs and the bearings are completely FUBARed. One side completely seized , the other side thinking about it!
Oddly the Shimano BB on my Cotic lasts through bad weather - both have the bearings in more or less the same position ( in fact the shimano ones are more "outboard"). So longevity really should be a big issue
Why have my bearings f***ed up so quickly? The seals appeared to have scored the actual bearing seals ( the red seal) which won't have eden it any good. It was very, very muddy ... is what have I done wrong?
( I am about to fit another set ....)
- Has thanked: 5455 times
- Been thanked: 13102 times
Re: Press fit bearings
So you've not changed anything in the setup/configuration apart from the bearings being swapped ?
What bearings did you go for in particular ?
In terms of bearing Enduro - it just came from Tredz - they should have been ACEB 5 rated.
(the bearings are 2437 LLB). But the original set had some outwear bearing seals - which were aluminium with a rubber coating. The new bearing came with nothing. Do I reused the seals
I am just wondering of the small black plastic spacer put too much "load" on them ...
New once ordered ( from Hendersons - 2437 bearings seem to be out of stock in the world)
what type of tensioning system does it use ? or what cranks and what torque ?
I am using shimano LX cranks - which according to D&D Cycles should be absolutely fine
The tensioning system - essentially crank fit and spacers ...
You're going to have to give us something in the way of pics then mate ? Or a link so we can see what it is etc.
- Has thanked: 2947 times
- Been thanked: 1884 times
Would those plasticy seals be orange in colour? They are a must. They act as an outer shield to the normal seals.
- Ditchfinder
- Has thanked: 622 times
- Been thanked: 692 times
Pressfit/Push fit are a PITA - but the Wheels Manufacturing one does give you a rigid shell - over the plastic really shit versions.
with them you can replace bearings etc - the only issue being availability. Bearings were finally source and were Enduro ones from Hendersons.
Getting seals was next to impossible - so I have had to go with some Shimano BB86 ones from Which - which are exactly the right size, and I hope will do the job.
My faux pas last time may have been to fit the seals the wrong way round ....
Looking at the set up , it should be no worse that the screw in BB - but , FFS , on a steel frame, just thread the BB !!
I hate the bloody things, I ended up with a £100 ceramic race in the bb of my trek (the side I kept killing) and a £15 oversize Bearing in the other side as that was all that would fit and just accepted that it was a two or three weekly job to flush the bb with IPA and re-grease. I fitted a Wfg BB to the wife’s trek and that was sealed about as well as a shuttle SRB on a cold day.
- Ditchfinder
It sure its pig iron - but certainly made out of the best material for MTBsDitchfinder wrote: ↑Mon Feb 08, 2021 11:19 pm If it's made of pig iron surely a new frame would be cheaper
