Chain degreaser what to use
- formula400
- Has thanked: 444 times
- Been thanked: 853 times
Right at times I use cans of clutch and brake cleaner to clean my cycle/motorbike chains as it eats through gunk very well. Are there any better 5/7ltr bottles I should use that are cheaper and don’t waste cans???
CBR650r
- Has thanked: 2912 times
- Been thanked: 1868 times
Re: Chain degreaser what to use
I use Muc-off degreaser/cleaner, its the almost luminous yellow/green stuff. Seems to work well without being too aggressive on finishes/paint.
- formula400
Is that strong enough for chains??MingtheMerciless wrote: ↑Sat Jan 30, 2021 9:25 am I use Muc-off degreaser/cleaner, its the almost luminous yellow/green stuff. Seems to work well without being too aggressive on finishes/paint.
CBR650r
- formula400
- Has thanked: 2830 times
- Been thanked: 550 times
I’ve got a 5l can of Holts brake cleaner, £15 from EBay and decant tear into a cheap spray bottle from B&Q. Far less wastage from aerosols.
- formula400
This stuff???Beancounter wrote: ↑Sat Jan 30, 2021 9:40 am I’ve got a 5l can of Holts brake cleaner, £15 from EBay and decant tear into a cheap spray bottle from B&Q. Far less wastage from aerosols.
https://www.carparts4less.co.uk/p/holts ... gIGvfD_BwE
And you don’t dilute it at all? Just spray on?
CBR650r
Yes, top tip, take chain off, put it in a Chinese takeaway plastic pot so its flat, cover with degreaser and put lid on, agitate and then leave for an hour or so before filling with boiling water and leaving for 5 mins, then drain remembering NOT to empty your SRAM eagle split links down the drain (.....not saying I've done that). Then pick the chain up (with something insulated it'll still be hot, again don't ask me how I know) and leave to dry. I also use the same technique for headset and BB bearings but either blast out the bearings with air duster or pump and then leave to dry on a hot radiator.
Or I get reasonable results filling the park chain cleaning tool with the stuff and doing it on the bike before sluicing to off with a watering can filled with hot water.
Yep, that’s the stuff. I don’t dilute it but then I don’t go crazy with it either.formula400 wrote: ↑Sat Jan 30, 2021 9:42 amThis stuff???Beancounter wrote: ↑Sat Jan 30, 2021 9:40 am I’ve got a 5l can of Holts brake cleaner, £15 from EBay and decant tear into a cheap spray bottle from B&Q. Far less wastage from aerosols.
Parafin or Patio Heater fuel as it's known in B&Q
Old plastic 5 ltr container, pour a pint-ish of parafin into container, drop chain in, lid on - shake like mad for minute. Empty container, tip out shiny clean chain.
- Has thanked: 5408 times
- Been thanked: 12939 times
- Has thanked: 1790 times
- Been thanked: 1431 times
- formula400
- Has thanked: 324 times
- Been thanked: 2173 times
My chains never get covered in gunk tbh, on the mtb I wipe it down after every ride with GT85. A tiny bit of lube and it’s ready. Gets replaced every 500 miles or so. On the motorbike pretty much the same process. Only time I have to clean a chain is when I buy a bike, I guess some people put lube on top of lube and don’t clean them. But same process GT85 and a brush and cloth
- formula400
ive done about 1000km on my cycle chain, and its pretty decent, just want to find the best easiest way to keep it like that
CBR650r
