Titanium brake caliper mounting bolts
Screens, footpegs, helmets, leathers, boots, jackets, luggage, basically anything biking related
Has thanked: 9819 times
Been thanked: 10144 times
M10 x 75 x 1.25
Four bolts,drilled for wirelocking.
These will cost you anywhere between £70 - £90.
I bought them used for £20,but they are too long. (poor obs) :roll:
If anyone wants them for twenty quid,I'll post them off.
Has thanked: 5450 times
Been thanked: 13085 times
Re: Titanium brake caliper mounting bolts
Arses, mine are 70mm not 75.
Been thanked: 7526 times
I took one look and thought "Caliper bolts, fuck off, they're way too long".
Then I remembered that modern bikes have radially mounted calipers. I've never had a bike with radially mounted caliper's!
Tricky
Has thanked: 2564 times
Been thanked: 2680 times
Post by Tricky »
Would these see you right?
https://www.ebay.co.uk/itm/Radial-Brake ... SwFNZWyYFp
I know they normally used to space the calipers out for bigger discs, but no reason why they couldn't go between bolt and caliper.
If not, or you don't fancy them, they ( or someone with a lathe) would sort it for Weeksy for a fiver ( well, yeah more accurately, £8 by the time you've added postage :) )
Tricky wrote: Sun Jan 24, 2021 8:45 pm Would these see you right?
They wouldn't work for me Tricky,mine are 60mm long,but could see the spacers working for Weeksy.
DEADPOOL
Has thanked: 75 times
Been thanked: 107 times
Post by DEADPOOL »
Turning Titanium is a nightmare. It's tough, gummy and has a habit of either burning up your tools or setting fire to the shed (or both).
Yeah they'd work, but not for me. I like things like this exactly as they should be. So I'm a no.
weeksy wrote: Sun Jan 24, 2021 9:06 pm Yeah they'd work, but not for me. I like things like this exactly as they should be. So I'm a no.
I understand. I thought about several solutions myself,but I knew it would annoy me every time I looked at it!
Now sold.
