good cheap cycle workshop stand
- formula400
- Has thanked: 444 times
- Been thanked: 853 times
as above, I quite fancy a work stand for the cycles to make cleaning easier , nothing ££££ any recommendations on decent one at the cheaper end.
CBR650r
- Has thanked: 5408 times
- Been thanked: 12939 times
Re: goo cheap cycle workshop stand
I get the impression to an extent you get what you pay for. Mine was about £50, 2 feet type, stability isn't wonderful, but it's ok for most things, I get around most jobs on it. I wouldn't recommend it though, but have no idea what make it I'd anyway as it's about 10 years old.
- Has thanked: 2156 times
- Been thanked: 426 times
- Has thanked: 2912 times
- Been thanked: 1868 times
Not much positive to add, I've a Bonty stand (which they don't make any more), it wasn't cheap. You have to be careful with the tripod positioning as otherwise it gets tippy, the tripod takes up a big area so its either outside or in the conservatory. Also the leg support struts ability to trap fingers make a 70's baby buggy look safe. I use it but only for big jobs or full strip downs.
- Has thanked: 1790 times
- Been thanked: 1431 times
I have a Park stand - it wasn’t cheap and it isn’t perfect. The clamp can freeze and need to be hit with a mallet. It’s. A two legged affair - and with a bike on it , it is stable.
Lidl / Aldi do them every now and again , and decathlon is normally a good shout
- Has thanked: 2830 times
- Been thanked: 550 times
I've got two stands, an older version of the Decathlon stand that Lostboy posted (mine has four legs instead of three) and a recently purchased Lifeline Pro Fork Mount.
https://www.wiggle.co.uk/lifeline-pro-f ... sJEALw_wcB
The Decathlon one was fine for road bikes but never really held mountain bikes at decent angle - the front wheel always dropped so the bike was in stoppie position. It did allow you to work on gears and helped with cleaning but was always spinning you needed the slightest bit of force on anything (bottom brackets for instance) so I'd end up loosening stuff with the bike on the floor and then lifting on to the stand. Became more of a PITA to use, hence the new purchase.
I chose the Lifeline stand because I've got an e-mtb and didn't fancy dangling it by the dropper post. Haven't tested in anger yet but it feels and looks more appropriate for my needs.
- Lifeline_Pro_Fork_Mount_Bike_Workstand_01.jpg (212.22 KiB) Viewed 1163 times
I would have thought an ABBA stand would work best on an e-bikeBeancounter wrote: ↑Wed Jan 13, 2021 10:52 am I've got two stands, an older version of the Decathlon stand that Lostboy posted (mine has four legs instead of three) and a recently purchased Lifeline Pro Fork Mount.
- Has thanked: 827 times
- Been thanked: 1231 times
I tried a cheap stand that looked just like the Park Tools one, it was rubbish and I took it back. I replaced it with Park Tools and the difference was huge.
I'm not one to splash out on branded stuff but this was worth it.
Re: good cheap cycle workshop stand
If you're minded, and can find the right base, this build-your-own looks like a decent option:
https://www.youtube.com/watch?v=AKiqDUSmJZA
Or follow Blake's from GMBN set-up:
https://www.youtube.com/watch?v=1qHCmCnA_Ks&t=20s
- formula400
Think that might be quite extreme
CBR650r
I've got an abba stand for my eMTB, it works a treat for doing things where you just need the bike held upright and the rear wheel an inch of the floor. I use it for day to day storage of the bike.Mr Moofo wrote: ↑Wed Jan 13, 2021 11:26 amI would have thought an ABBA stand would work best on an e-bikeBeancounter wrote: ↑Wed Jan 13, 2021 10:52 am I've got two stands, an older version of the Decathlon stand that Lostboy posted (mine has four legs instead of three) and a recently purchased Lifeline Pro Fork Mount.
I don't think they make them any more, which is a shame
I've got one lurking in the garage and if it was less of a PITA to use I'd have given it a shot.formula400 wrote: ↑Wed Jan 13, 2021 3:19 pmThink that might be quite extreme
I think he was.Beancounter wrote: ↑Wed Jan 13, 2021 3:35 pmI thought Moofo was having a laugh about using an ABBA stand!
Taff wrote: ↑Wed Jan 13, 2021 4:14 pmI think he was.Beancounter wrote: ↑Wed Jan 13, 2021 3:35 pmI thought Moofo was having a laugh about using an ABBA stand!
