slide in steel bar for garage doors
formula400
Has thanked: 444 times
Been thanked: 863 times
Post by formula400 »
Right after what happened to the out house, I want to add a little security to my garage.
I was looking at a slide in steel bar to go across the door, they are wooden and open outwards,
https://www.ebay.co.uk/itm/362589269493
https://www.ebay.co.uk/itm/ULTIMATE-Sec ... 2051040438
and 2 extra brackets for the centre's of the doors,
I feel visually they are a good, I know if they really want to get in they will, the garage is alarmed, but id like to make it more agro for them, the person that tried the out house had a quick try and buggered off, police come this morning as I reported it last night and said most people look for something easy and try then move on, hoping this bar could make it too much for the average burglar.
CBR650r :mrgreen:
Has thanked: 5449 times
Been thanked: 13085 times
Re: slide in steel bar for garage doors
Looks good to me.
formula400
do you think it worth having the extra bracket in the centre of the door (the open from the centre outwards)
CBR650r :mrgreen:
Has thanked: 2940 times
Been thanked: 1882 times
Make it noisy and awkward but try not to make it look like you’ve got the Crown Jewels stored in there.
Been thanked: 2615 times
I'd say the centre brackets are essential, maybe not for security but ease of use. Without them the bar can get horribly close to biting your fingers badly.
Maybe put a flat runner on the extraction side to stop the bar dropping too.
formula400
cheb wrote: Sun Jan 10, 2021 11:11 am I'd say the centre brackets are essential, maybe not for security but ease of use. Without them the bar can get horribly close to biting your fingers badly.
you mean like a mini shelf???
CBR650r :mrgreen:
Yes. Just a length of 45mm wide wood would do I reckon.
formula400
cheb wrote: Sun Jan 10, 2021 11:15 am Yes. Just a length of 45mm wide wood would do I reckon.
and drill that to the door it self?
CBR650r :mrgreen:
formula400
also as it come with M8 coach bolts will a 8.2mm drill bit for wood be ok???
CBR650r :mrgreen:
formula400 wrote: Sun Jan 10, 2021 11:16 am
I was thinking it being beside the door so as you pull the bar out from the brackets on the door the bent over end rests on it. The bar will be heavier than you expect and they are annoying unbalanced when being extracted. My first spawn had one on their shed in Crawley.
formula400
cheb wrote: Sun Jan 10, 2021 11:26 am
oh that makes sense, so a block for the end to rest on, makes sense.
CBR650r :mrgreen:
Pretty much.
formula400
googling a bit, now I am confused, ill need to drill holes in the wood for the M8 coach bolts what size drill bit will I need, I think 8.2mm will be too big
CBR650r :mrgreen:
8mm will do, and then tap gently through with a hammer.
Has thanked: 836 times
Been thanked: 1238 times
Do you think they saw anything valuable during the last attempt? If they did they are likely to be more determined next time.
They are also likely to be one of your neighbours so don't make it obvious when you are out.
formula400
There is nothing in the outhouse they tried to get in, you can see some chocolate, old boots, garden chairs and some baking bits
CBR650r :mrgreen:
Has thanked: 1346 times
Been thanked: 1722 times
formula400 wrote: Sun Jan 10, 2021 11:42 am googling a bit, now I am confused, ill need to drill holes in the wood for the M8 coach bolts what size drill bit will I need, I think 8.2mm will be too big
Assuming your meaning M8 machine thread on the coach bolts then 8.2 mm will be fine.
Theres usually a domed head which should always go to the burgler side, thats so they can't get a grip on it with a spanner.
Its usually got a square section under the domed head which stops it from rotating when you tighten the nut on the other (nside the shed) end.
formula400
demographic wrote: Sun Jan 10, 2021 2:44 pm
yeah they are those.
when you say fine, should I go 8 or 9, how do you work out the correct size???
CBR650r :mrgreen:
Well, if I was drilling the hole I'd use an 8.5mm but thats cos my drill index (box of bits) goes up in half mm sizes and its the next size up from 8mm that I have.
Its better being slightly bigger than the thread size.
If you have 8.2 thats fine, if it sticks in the hole slightly on the way through, give the domed end a tap with a hammer. Thats with dome headed coach bolts that have a machine thread.
Coach bolt.
If you were using coach screws however, they have a big woodscrew thread and dont have a nut to fix to the other end the hole needs to be about the size of the root of the thread.
Coach screw.
If the bolt has a nut on the end and the thread doesn't grip the wood then I'd make a 9mm hole to allow for the hole being slightly out.
