Wheel axel greasing
formula400
Has thanked: 444 times
Been thanked: 853 times
Wheel axel greasing
Post by formula400 »
Question, once bike been cleaning and dried what’s good for greasing the through axels and peddles abs bottom bracket???
GT85, WD40??? Or a a proper grease for cycles???
Thanks
CBR650r :mrgreen:
Has thanked: 5408 times
Been thanked: 12939 times
Re: Wheel axel greasing
I use either Weldtite TF2 grease
Or a generic https://www.ebay.co.uk/itm/White-Marine ... SwN-NdQmbd
Has thanked: 2912 times
Been thanked: 1868 times
PROPER GREASE!!!!! But not Muc-Off grease, it’s rubbish. I use White Lightning crystal grease at the moment but Juice Lubes stuff is pretty good as well
formula400
sweet, cheers you two
CBR650r :mrgreen:
As an aside, apparently the pro’s run ceramic wheel and bb bearings with a very light oil in them in their race bikes (which obvs gets cleaned and relubed after every event. Trying to save every last milliwatt by reducing drag!
Taff
Has thanked: 253 times
Been thanked: 874 times
Post by Taff »
I had to change a rear hub a few years ago because the thru axle had corroded and siezed. It was a right bitch to get the wheel out of the frame and I couldn't get a replacement through axle so I had to get a couple of bits machined to get the bike rideable again.
Keep those axles greased. :thumbup:
formula400
Got some TF2 grease on the way 😎😎😎
CBR650r :mrgreen:
formula400 wrote: Mon Jan 04, 2021 3:32 pm Got some TF2 grease on the way 😎😎😎
I use TF2 for most things
