Recommend me a compressor
Lutin
Has thanked: 257 times
Been thanked: 331 times
Post by Lutin »
I'm after a compressor and associated kit to do some soda blasting. What size of compressor would the community recommend? I think I'm correct in thinking that belt driven, rather than direct drive, is preferred.
I'll be wanting to soda blast some very solid and glazed internal doors for starters. I'm sure I'll end up using for other purposes - as you do.
Ant
Has thanked: 39 times
Been thanked: 227 times
Re: Recommend me a compressor
Post by Ant »
Rotary screw compressor and a 500 litre receiver. Abac or Compair.
Lutin
Post by Lutin »
Ant wrote: Sun Dec 13, 2020 11:44 pm Rotary screw compressor and a 500 litre receiver. Abac or Compair.
Thanks for that. Would be great if I was operating a commercial venture.
Completely my fault for not specifying that this is for DIY use. Ho hum. I'll learn eventually.
Ant
Post by Ant »
You may struggle doing blasting from a small compressor. I know a guy who tried with a 100 litre compressor, then a 150, then a 200 and he's still needing plenty more air.
Has thanked: 1507 times
Been thanked: 1411 times
60gal 2 stage minimum for blasting
Nordboy
Has thanked: 299 times
Been thanked: 565 times
Post by Nordboy »
I got mine from sgs engineering, hasn’t let me down and there’s loads of sizes.
