Shifting getting harder as you go to the bigger cogs?
Has thanked: 5453 times
Been thanked: 13102 times
Had some issues shifting in my lads Sworks today. Was just missing loads of gears.
SRAM xx1 shifter and mech, 11sp. Bike is a 2016.
So I checked indexing on workstand and it was all over the place.
I thought I'd swap the inner but didn't make much difference.
I then found a slightly loose hanger mount bolt, but again that didn't do much.
Cleaned and lubed the mech, the shifter which helped a bit, but in the end it came down to the gear outer that got me all the gears nicely.
Going from big cog on the back and down through the gears is super smooth and slick, but going from the 11t up to the bigger ones it gets gradually harder. I assume because you're putting more and more tension on the spring.
But I've got 11sp GX on my G160 and I'm sure my shifting is just as easy at both ends, or if harder, it's really not by much.
Chatted with my lad who said it's always been harder to get into the bigger cogs.
Am I missing anything here? I'm actually thinking of getting a FX shifter and mech to make it easier.
Has thanked: 2947 times
Been thanked: 1884 times
Re: Shifting getting harder as you go to the bigger cogs?
It would make more sense as your tensioning the mech spring more but I can’t say as I’d noticed it being a problem on the Enduro which is X11. Have you checked b tension and hanger alignment (not teaching you to suck eggs)?
Cable wear and routing is more of an issue for heavy shifts. After 30+ years of MTB I’ve got “trigger thumb” which is bloody excruciating when it kicks in.
AXS and the problem goes away but I’m guessing Weeksyminimus needs to polish a decades worth of motorcycles for that😂
Ha ha. I'm not sure what he'd need to do, but I'd start with a degree in brain surgery if I were him.
Asian Boss
Has thanked: 498 times
Been thanked: 650 times
Post by Asian Boss »
I noticed my eight year old finds it harder to get onto the bigger cogs at the back. He can do it but it takes a bit more grip and twist. I think it's just the nature of these sort of gears. He has a kid's Cooker Charge FWIW.
Asked my lad to go test it this morning
"i can't reach the triggers now".
I tried and he's correct, the shifter trigger to go to bigger cogs is MILES away from the bars..
So investigation time was needed.
Eventually i found on the underside of the shifter there's a set of markings from 0deg to 30deg one way and 30deg the other way... It was way outside the parameters on the off-side. So i moved it to 0deg, tightened it back up and that brings the shift lever right back to position. Wow... Wasn't aware of that.
The added bonus is, i'm sure that's also made the changing gear easier too, so with the new outer and inner fitted, along with this, his shifting seems pretty perfect. He'll test tonight when home from school, but i'm happy.
Well he's happy too, smooth both up and down the box now. Effortless through all gears, so he's a very happy lad.
