Paddock stands, bike lifts etc.
Whats the latest and greatest with these then?
I have a few jobs I need to do which involve suspending bikes to various degrees and I am not sure what to get. As an example....
I have a CBR600 (conventional box section swingarm) which I need to remove both wheels from to get tyres. I also want to replace the rear shock and forks. This bike has a centre stand so I could probably fudge my way through if needed.
I also have a Speed Triple with a SSSA that I plan to completely strip/rebuild, right down to getting the frame powder coated. I.e. everything out. No centre stand.
I currently have a paddock stand just for the Speed Triple, it's the kind which slots into the rear wheel hub.
What would be the best/most universal way of picking these bikes up?
Been thanked: 9496 times
Re: Paddock stands, bike lifts etc.
ABBA stand innit.
Been thanked: 4529 times
They go in the swingarm pivot right?
I suppose if I am taking the swigarm out I can remove the rest of the bike first so it's light enough to manhandle. :D
Mr. Dazzle wrote: Sun Nov 15, 2020 11:12 am They go in the swingarm pivot right?
There's an optional kit that replaces the footrests with ABBA mounts so you can remove the swingarm.
Been thanked: 15495 times
Constands don't mount through swingarm mount. But through frame mount points. So may work better.
iansoady
Has thanked: 72 times
Been thanked: 244 times
Post by iansoady »
I use one similar to this:
I've successfully lifted bikes from a Honda SLR650 to a Norton ES2 via Guzzi V50, Matchless G80 etc. I have had to make timber bases to support the crankcases on some however.
It works well, is easy to stow under the bench when not in use and is reasonably stable with the bike tied down. If space is limited you can also shuffle the whole thing sideways to get access to both sides. Mine was about £80.
Ian.
1952 Norton ES2
Has thanked: 7623 times
Been thanked: 5930 times
Is this a bit too old school?
I've Harris paddock stands for normal stuff,anything else the Abba stand comes out.
Really the Abba can do it all,but I had the Harris stuff from way before it arrived.
The Skylift thing Abba do looks useful,especially if you don't have a ramp/lift.
With Abba stands, when you're doing front end stuff I guess you just put something under the headers, shove a bag of cement on the pillion seat etc?
Mr. Dazzle wrote: Sun Nov 15, 2020 1:25 pm With Abba stands, when you're doing front end stuff I guess you just put something under the headers, shove a bag of cement on the pillion seat etc?
Abba stand front wheel lift kit :)
Image2019-06-07_07-31-22 by Steve Weeks, on Flickr
Genuine ABBA strap too? ;)
yes, comes with the kit.
Buckaroo
Has thanked: 1048 times
Been thanked: 1108 times
Post by Buckaroo »
iansoady wrote: Sun Nov 15, 2020 11:59 am I use one similar to this:
What's the weight limit on this lift? I need one for 250kg plus.
iansoady
Post by iansoady »
I can't remember exactly but well over that.
Parents have bought me an ABBA stand with front lift kit for Crimbo. Cheers peeps. :D
Should be just about perfect for getting 2 new tyres, new shock and new forks bits onto the CBR.
scottyuk
Has thanked: 167 times
Been thanked: 257 times
Post by scottyuk »
It depends what you're after or need. I've always suffered from lower backache after working on bikes. I went for the Abba Skylift and no longer have that issue. I use it on three bikes so just need the different adaptors which just slip in place. The Skylift doesn't just give the benefit of having the bike at the height you need it for a task but can go arse up or nose up. Also great for moving a bike around when up and being worked on. I've used this flexibility for a few things. In this case, it was cleaning out the disk bobbins. I totally recommend one. However, I do also have paddock stands as sometimes I just want the bike up for a quick chain lube etc and the Abba does take a bit longer to get sorted.
20200219_175702 (Small).jpg (162.89 KiB) Viewed 1762 times
Has thanked: 2557 times
Been thanked: 4167 times
Another vote for the Abba Skylift here. You can do jobs with the Skylift that would be next to impossible with other stands. As an example, I needed to get the shock off my KTM Duke 690 to fit a different spring so i used the skylift in the 'stoppie' position. The back of the bike wasn't far off the ceiling. It would have been a pig of a job even with the conventional Abba stand, as the shock has to come out from underneath and the rear wheel has to be at maximum compression (I used a ratchet strap through the wheel and round the subframe.) I was able to do the job in complete comfort sat on a stool next to the bike and it took about half an hour to remove and re-fit the shock.
mangocrazy wrote: Fri Jan 01, 2021 2:56 pm Another vote for the Abba Skylift here. You can do jobs with the Skylift that would be next to impossible with other stands. As an example, I needed to get the shock off my KTM Duke 690 to fit a different spring so i used the skylift in the 'stoppie' position. The back of the bike wasn't far off the ceiling. It would have been a pig of a job even with the conventional Abba stand, as the shock has to come out from underneath and the rear wheel has to be at maximum compression (I used a ratchet strap through the wheel and round the subframe.) I was able to do the job in complete comfort sat on a stool next to the bike and it took about half an hour to remove and re-fit the shock.
For shock I just used the grab rails and ratchet straps on the rafters. 10 mins
Has thanked: 19581 times
Been thanked: 4953 times
Damn that looks awesome! I've got a front/headstock stand and a normal rear stand. But that one looks awesome!! :banana-wrench:
