I keep a spreadsheet of everything that I do to the tiger because I like to know how long things last - brake pads, tyres etc and how much oil I'm adding to the engine.
In column A I have mileage, column B the amount of oil added in ml.
what I'm trying to get excell to do is tell me how much oil is added per 1000 miles so that I can pick up any change (increase) early on, any ideas?
A little excell question
- DefTrap
- Has thanked: 2259 times
- Been thanked: 2190 times
Re: A little excell question
So in cell c2 you want =b2/(a2-a1)
That will give you the oil per mile for the first entry.
Then just copy it down the c column.
thats great, thanks
I've modified that slightly to smooth out the graph and currently have =sum(B2:B6)/A6-A2 which gives me the total oil added / mileage range which is the sort of rate that I'm looking for.
