Mr. Dazzle wrote: Tue Nov 03, 2020 8:22 am
weeksy wrote: Tue Nov 03, 2020 7:22 am
Mr. Dazzle wrote: Mon Nov 02, 2020 4:56 pm
The point of trackdays would be to improve my own skills, so lower grip tyres wouldn't really be a problem. I'm more interested in learning how to recognise the limits than actually going that fast.
That's not actually realistic. Very very few riders manage to do so, they only reach the limits of their own balls. Reaching the limits of the grip of the bike and recognising that is the realm of a very small group of riders.
You'll get the usual "oh i was spinning the rear out of the corners..." but mostly that's a complete load of shit.
That's kinda what I mean. The limiting factor is me, so sticky tyres etc. are a waste of money.
Leanr how to grow bigger balls if you wanna phrase it that way instead. Or learn how to brake harder without locking up etc.
Serious answer then. Learn to get absolutely pin-point on your lines... learn where the entry to the corner is, then aim to nail it every single time. Ditto the exit - It's reading the line backwards from the exit (where you're on the power aimed for the next corner) that controls where you're turning-in on most bends. The apex - usually handily marked with a cone on a track day - is useful for linking them together. Once you know WHERE you are tipping into the corner, you'll know where you should be easing off the brakes... once you know that you can work on braking harder and later. Then you can work on carrying more speed and lean through the turn, and getting on the power harder and earlier.
One thing that worked for me learning the Brands Indy circuit was doing the entire lap in one gear. That way all I had to worry about was throttle and steering input. As the speed comes up, then you start to need the gears, but for learning your way round, minimise the gear shifts. It's one less thing to get wrong.
