Brake pads for the cage
- Has thanked: 1264 times
- Been thanked: 1188 times
Apologies if you think this should be in Shed or Mechanics.
Do any of you more 'progressive' drivers have any brand preference for brake pads in your cars? Looking for replacement for the XF.
Thanks.
Thanks.
- Been thanked: 7530 times
Re: Brake pads for the cage
I always fit the cheapest brand I've heard of from Eurocarparts.
Unless you're doing trackdays or you have proper racing style callipers then sporting pads are just a waste of money.
Thanks. Wasnt thinking of sport pads, im mostly a plodder, but was hoping to avoid eating discs if some compounds are more aggressive. Prolly overthinking it
If you're doing them yourself and don't have to pay for labour, it's a pretty cheap job usually.
I did the front pads and discs on my 330i for under £50 from ECP.
- rodbargee
- Has thanked: 353 times
- Been thanked: 980 times
I hav ejust re-repalced the front discs on my Discovery 3 the OE landrover discs have warped inside six months! :ugeek: so I have gone over to Brembo discs instant judder cure and looking at the rears which i did some time ago they wear slowly brembo pads too
- Has thanked: 836 times
- Been thanked: 1239 times
I think the problem is environmentally friendly brake pads, I have got used to replacing disks with every set of pads. The front of my XF needed doing earlier this year and the rear need doing now but at £500 an end I'm looking for a cheaper way of doing it, I'm tempted to do it myself but with only one car I'm knackered if it goes wrong.
- Has thanked: 15957 times
- Been thanked: 10248 times
Always used Eicher from ECP. Work fine in our cars, but then we only drive normally...
- MrLongbeard
- Has thanked: 599 times
- Been thanked: 2443 times
EBC for me, never been a bother, although I have some Brembo's to fit on my daughter's mini.
- Has thanked: 657 times
- Been thanked: 362 times
Brembo are surprisingly cheap for cars (compared to bikes) and are top quality. Eurocarparts is your friend
- Has thanked: 2551 times
- Been thanked: 6247 times
My commute used to involve driving across most of Milton Keynes twice a day, which means doing about 25 "big stops" from 70 into the roadabouts* every day. Therefore I used to munch through brakes pretty quick, probably two sets of pads a year.
I just fit whatever was cheap off ebay. There are some small variations but in day to day road driving it makes little difference IMO. I will however say that the present Eibachs have the strongest smell
*I suppose technically I wasn't forced to be a late braker...
- Has thanked: 164 times
- Been thanked: 308 times
I was using either Brembo or Pagid from ECP or Ferodo when I could find them for the Discovery (pretty sure they supply OE).
Changed two of the cars using Eicher about a year ago and one pad from each has sheared off from the backing pad so I'm back to Brembo or Pagid.
Had similar with Mintex a few years back - seems to be the pads are more liable to corrode, but then we're in a pretty harsh environment. Probable that people not living on the west coast of Scotland won't have the same issue.
I was once given a set of 'Allied Nippon' pads with a Mondeo I bought.
Scary lack of braking from those so were straight off and in the bin.
I see a few of you use Pagid. i stopped using them as they give off so much brake dust. Is that not the case with them anymore?
Since going to brembo on cars I've never gone back, bought a cheaper set of pads from ECP once and replaced them within days, the feel was crap and the fade was awful.. like almost had a nasty one had to use the handbrake awful.
Think I need front pads on my 330i, would you recommend Brembos for it?The Martian wrote: ↑Tue Oct 20, 2020 12:06 pm Since going to brembo on cars I've never gone back, bought a cheaper set of pads from ECP once and replaced them within days, the feel was crap and the fade was awful.. like almost had a nasty one had to use the handbrake awful.
Definitely.Taipan wrote: ↑Tue Oct 20, 2020 1:57 pmThink I need front pads on my 330i, would you recommend Brembos for it?The Martian wrote: ↑Tue Oct 20, 2020 12:06 pm Since going to brembo on cars I've never gone back, bought a cheaper set of pads from ECP once and replaced them within days, the feel was crap and the fade was awful.. like almost had a nasty one had to use the handbrake awful.
Was hoping you'd be alongThe Martian wrote: ↑Tue Oct 20, 2020 9:05 am Brembo are surprisingly cheap for cars (compared to bikes) and are top quality. Eurocarparts is your friend
When the discs are due, match em up Brembo too, probably half the price of OEM with better performanceslowsider wrote: ↑Tue Oct 20, 2020 2:52 pmWas hoping you'd be alongThe Martian wrote: ↑Tue Oct 20, 2020 9:05 am Brembo are surprisingly cheap for cars (compared to bikes) and are top quality. Eurocarparts is your friend
